Using gasket paper/cork for the runners
Old Jun 2, 2002 | 09:34 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Stock runner gaskets are puny for my runners and intake and porting them makes them really fragile..Can I just get a gasket sheet(paper or cork) and make it..Would this work?Im wondering cause stock gaskets have metal in them...BTW It takes 3 weeks for any aftermarkets to get here..I dunno if it makes a difference but I blocked the EGR ports from the heads(using Felpro 1206)so the intake should be cooler(?)
Daz
87 IROC TPI
Old Jun 2, 2002 | 09:15 PM
ImportsRsloths's Avatar
If your custom "cork" gasket cutting skills are anything close to your skills in making your custom signature, Id steer real clear from making those gaskets!!!!!
Old Jun 2, 2002 | 10:10 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I got my SLP siamesed runners used, and didn't have any gaskets for them, so I made them out of the blue paper gasket material that you buy in sheets. Apparently it sealed ok, as I don't appear to have any vacuum leaks. Making the gaskets was a real PITA though, it took me at least an hour. You could always order aftermarket gaskets. I know SLP sells them separately, and Accel and Edelbrock might also. But price-wise, it'cheapest to cut your own.
Old Jun 4, 2002 | 12:19 PM
dsaint1347's Avatar
Hey Daz, has anyone ever told you look like the **** star Ron Jeremy.
Old Jun 4, 2002 | 12:44 PM
tpi_roc's Avatar
Buy TPiS large mouth gaskets, they'll fit your porting and you dont have to worry about sealing, then you'll have bragging rights that you spent ungodly amounts of money on TPiS parts
Old Jun 4, 2002 | 02:02 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Mr. Gasket sells large mouth gaskets, probably for 1/2 what TPIS charges. They have a 1.75" diameter, so they're a good match for the accel runners as well as the SLP runners with a snip of the scissors. Summit usually stocks them too.
Old Jun 4, 2002 | 04:22 PM
Blackened's Avatar
Ughhh... DOH! That IS a picture of the **** star, Ron Jeremy.
Old Jun 4, 2002 | 04:23 PM
Blackened's Avatar
No ****..! What a waste of bandwidth !!!
Old Jun 8, 2002 | 10:53 AM
dsaint1347's Avatar
EEK!
Why would anyone use him as an avator? They might as well put his ******* d(rick) as an avator. Me... I would prefer having a female pornstar.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
Royal_Z
Sep 30, 2015 08:45 PM
