Shouldnt engine run in limp home mode with MAP unplugged??
Old Jun 7, 2002 | 10:23 PM
MeanYellowZ's Avatar
still trying to get this car to run right, and in trial and error I tried with the map unplugged to no avail.
Old Jun 8, 2002 | 09:05 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Can't tell you with 99% accuracy, but most likely not...the ECM will probably default to running off "assumed" values based on TPS input. Least that's what a MAF car will do...on MAF, if it fails while driving, ECM stores last known MAF input...if unplugged, then will store some high number of MAF and run off TPS, etc and still make A/F (or try) corrections.
I think the only way to run in "limp home mode" is total failure of PROM...not just one sensor input. LHM is preset externally to the PROM, IIRC.
So what's your problem/car/induction anyways?
Old Jun 8, 2002 | 09:21 PM
car is idling at 2500 RPM, engine is 305 TPI
check my other post under TPI forum
Old Jun 11, 2002 | 11:16 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
8mike9, you are wrong.
Old Jun 12, 2002 | 12:42 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
In whch regards? Please elaborate.
Old Jun 12, 2002 | 04:42 PM
tpi_roc's Avatar
The MAP should have max and min tables for a given rpm on map reading, if its outside of that you should certainly throw a code, and the ecm may or may not go into limp.
A MAF car will because its so heavily dependant apon LV8 and Airflow in almost all its tables
Old Jun 16, 2002 | 08:33 AM
Car: 1991 Firebird
Engine: 427 LSX
I believe that when you unplug the map sensor the car will use predetermned values based on this fault code and thus be in limp mode. This means rich a/f mixtures, 22 degrees max timing or so, and possibly other things to protect the engine. Since the map sensor in a sd car is very critical, unplugging it leaves the computer blind.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
