swap maf to speed/density
Old Jun 8, 2002 | 01:34 PM
fourspeed's Avatar
has anyone changed this system over?
how much was cost?
was it worth the swap?
Old Jun 8, 2002 | 02:03 PM
BitchinCamaro's Avatar
http://www.eecis.udel.edu/~davis/z28/ecm_swap_730/
That should give you an idea of whats involve and the cost. Its not worth swapping unless you are running 12s or are big into chip burning.
Old Jun 9, 2002 | 06:56 PM
Jza's Avatar
Jza
Depends on what you consider "worth". I converted my MAF to speed density for no money and 4 hours of my time. Obviously it helps to have that stuff laying around, and I did the conversion while I was at work (I had a boring job with lots of free time back then).
I can't see a conversion costing more than $60 if you get boneyard parts (computer, MAP sensor) and you re-pin your MAF harness.
BTW, don't try it if you can't read an electrical diagram.
I re-pinned my harness using that exact link that BitchinCamaro gave. It's a bitchin site; my hat's off and a big ol' thanks to Mike Davis.
Old Jun 14, 2002 | 01:57 AM
RBud350tpi's Avatar
Mike Davis did a lot of leg work for us
Old Jun 14, 2002 | 01:16 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
psssst..... Some of us MAF guys are working on an all 'software' change to MAP without having to go to the 730 ECM and repin the connectors of the harness or get a different harness..... This process will only require three minor wire changes to accomodate a MAP sensor instead of a MAF sensor, but is basically all done with the use of a different mask for the ECM. There are people out there that have it up and running successfully already..... Check out the DIY-PROM board for more info .
Old Jun 14, 2002 | 02:34 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
wow, bout time...
Old Jun 14, 2002 | 03:44 PM
tpi_roc's Avatar
There are a few turn offs to it though.
like it being all metric based
no more "22 lb/hr" injector constants
You'll have to do conversions to figure out what you're changing and what you're changing it to.
Old Jun 14, 2002 | 05:09 PM
AlexJH's Avatar
Engine: 5.7L V8
Oh, you yanks are wimps, you should've gone to metric a long time ago like the rest of the world.
The other problem that I've noticed is that it doesn't support the AIR stuff... but if you leave those wires disconnected it should just dump to the cat all the time... no big deal.
Old Jun 14, 2002 | 09:43 PM
Jza's Avatar
Jza
Originally posted by Matt87GTA
psssst..... Some of us MAF guys are working on [etc.etc.]
Yeah, I saw that. I personally wouldn't be interested unless there was a way to use BOTH MAF and MAP sensors and have them co-exist harmoniously. Otherwise, it was just too easy to simply re-pin the harness and swap computers. I don't know why people make such a big deal out of the re-pinning. It was pie.
Old Jun 14, 2002 | 10:07 PM
Swapmaster's Avatar
Co-existance would be nice but the reason to change is that the
MAF only reads up to a certain amount of air and it don't take long
until you exceed it's capabilities.
And from what I understand, the SD is easier to burn proms for.
Burning proms is something that I really need to get into.
Old Jun 17, 2002 | 10:53 AM
AlexJH's Avatar
Engine: 5.7L V8
Repinning looks easy, finding or buying a 730 is expensive!
Old Jun 17, 2002 | 10:57 AM
tpi_roc's Avatar
I repinned my 870 to a 165 without a hitch.
I desperatly want to go to SD and have been searching for a harness forever. I think going through 2 repins will leave me with to much of a rats nest to try to figure out in a pinch.
Old Jun 18, 2002 | 01:16 AM
RBud350tpi's Avatar
I repinned mine twice and have no poblems. Take your time and don't bend up the pins. You will be fine.
trevor1010
Aug 26, 2015 02:41 PM
NBrehm
Aug 25, 2015 11:49 PM
nuggie
Aug 25, 2015 01:27 PM
trevor1010
Aug 24, 2015 08:34 PM
Bert87
Aug 23, 2015 03:50 PM
