Intermittant Code 54
Old Jun 11, 2002 | 12:24 PM
Bort62's Avatar
Fuel pump Circut, Car runs Fine.
Any ideas ?
Old Jun 11, 2002 | 12:41 PM
tpi_roc's Avatar
Fruity fuel pump relay?
Old Jun 11, 2002 | 01:13 PM
Bort62's Avatar
You would think so, But why Does it Run Fine ?
OIl pressure switch keeping it Running when the relay conks out
Car takes a bit of cranking when "cold" to get started, maybe the relay isnt workig right and its waiting for the oil pressure switch to energize the pump ?
so it needs oil pressure to build while cranking, wich takes a while ?
Old Jun 11, 2002 | 02:04 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
replace the relay, it's about $12.
If it isn't the relay that was the problem, you're only out $12.
Old Jun 11, 2002 | 02:29 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
"Code 54... where are you!?"
Ok... sorry. Anyway, judging by your description, I'd also agree that the relay is shot. The oil pressure switch is powering the fuel pump when the relay is shot.
Old Jun 11, 2002 | 02:50 PM
Bort62's Avatar
Will try it out, Thanks.
Old Jun 11, 2002 | 03:43 PM
88 IROC BOB's Avatar
Code 54 problem that I had was not cured by replacing the relay. I put in a new ecm and it fixed it.
I also had a hard stearting problem which I thought would get better when the code 54 was cleared up but it didn't. I had to replace injectors and it now runs like a top.
Bob
Old Jun 11, 2002 | 04:00 PM
Bort62's Avatar
Well we Will try the Relay, If that dosent take care of it Ive got a Spare ECM here.
Old Jun 11, 2002 | 07:19 PM
Jim85IROC's Avatar
I found out the hard way that you can't power a heated 02 sensor with the green wire from the fuel pump plug. That's the signal wire from the ECM.
Goddamned electrical engineer and I manage to screw up a 2 wire installation.
Old Jun 11, 2002 | 08:29 PM
Bort62's Avatar
It happens to the Best of us
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
Reid Fleming
Oct 10, 2015 09:56 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
