HELP!! pulling intake off of a 91Z TPI, what mods can i do?
Old Jun 13, 2002 | 08:14 PM
taner's Avatar
well my friend's 91z has a leaky intake. so off it must come. what mods can i perform on them? i have heard of porting the plenum as well as the lower base portion? must stay cost effective here, buddy is short on $$$$
is a edelbrock base worth the money? then maybe hand port the upper plenum
tia for any suggestions.
taner
i was reading up on the siamesed porting of the lower intake. hmmm, whatever we can do i guess...
Old Jun 13, 2002 | 08:53 PM
89BlueTA's Avatar
You can knock down the walls in the plenum just behind the TB opening, the port match the rest of the intake. It is pretty obvious what material to remove.
nick
Old Jun 13, 2002 | 09:51 PM
taner's Avatar
can i not do anything to the lower base? or did you mean that as well?
thanks!!!
Old Jun 13, 2002 | 10:45 PM
IROC57TPI's Avatar
Siamese the lower base. If you do a search on this board (top right of page is the button. Look it up...its a relatively cheap and simple mod that moves the RPM range of the intake up to 6000 rpms.
Old Jun 14, 2002 | 09:40 AM
TransAm87's Avatar
Port and clean up your plenum and your runners, and then you can perform work on your stock intake manifold, not worth buying an aftermarket one, unless you plan on modding the rest of your car
Aj
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
