siamese runners
Old Jun 15, 2002 | 12:41 PM
PIMPINPHIL's Avatar
siamese runners
hi,
how exactly do you siamese your runners?ive tried lookin in the search thing,i mean are you basically just grinding all the metal between the seperated holes?and having the air get sucked through both intake ports?what about gaskets if you do this?just run around the top and bottom part of them?i think my engine just might need this,i dont much bout engines,but i would hope mine would create power throguh 5000 rpm's,and if my tpi wont go that far,i think i should try every bit i can to make it go that far.thanks.
Old Jun 17, 2002 | 01:11 PM
highhat's Avatar
siamese your base
IMO you should siamese your base instead, many people have had great success with this. Do a search on it. Also you need a cam that makes power in that range, but I may be wrong on that.
Old Jun 17, 2002 | 01:15 PM
tpi_roc's Avatar
I have a siamesed base only, stock runners/tb/plenum. It certainly shows gains.
As far as *how* to do it there's a great article in the tech article section look there.
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
