TPI won't start, need help
Old Jun 17, 2002 | 08:39 PM
89formula350tpi's Avatar
Car: 1989 Firebird Formula
Engine: 350 tpi
My car has been running like crap for a while. I've changed all the obvious things and it didn't help. So I bought a digital ohm meter to test my injectors. I had jumper wires between the injectors and the injector plug. I got weird readings. I wasn't really sure ff this was the right way to check them. But then the wire moved and hit the runner and sparked a few times. But I didn't think anything of it. I started the car and it ran worse than before then it died. Then I checked the fuses and sure enough I blew the 10 amp injection fuse. So I replaced it but the car still won't start. I can smell gas when I crank the car, I'm getting spark at the coil and at the plugs and my fuel pressue is good. I called my mechanic and he was puzzled too, but he told me to unplug all the injector wires and try to start it because it was probably flooded pretty bad. So i did that and it started for a few seconds then died again. I plugged the injector wires back in and now its back to no starting and a strong smell of gas. i ordered new injectors but i think I have another problem too. Please help. Thanks.
Old Jun 17, 2002 | 10:22 PM
gmanrs70's Avatar
Have you tried pushing on the gas peddle when you are cranking it over? If you have does it start or no?
Old Jun 17, 2002 | 10:55 PM
Poppa Chubby's Avatar
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
I had the same problem about 2 weeks ago - I had put in some new Accel injectors and I tore the o-rings. When I would go to start the car it would just **** fuel every where. I had it all over the intake.
Old Jun 18, 2002 | 03:30 PM
Engine: 350 tpi
I tried pushing down the gas pedal and it didn't help and I'm not leaking any gas but I can smell it.
Old Jun 20, 2002 | 12:22 PM
Knight350's Avatar
I had a similar problem, the problem with mine was I could keep the car running if I keep the pedal down a bit to keep the rpms above 500... the fix was a bad IAC(idle air control)... ask you mechanic about that... try removing and cleaning with wire wheel first. The part cost about 120.00 (CND).. if its not that you may want to check the fuel pump relay and then the fuel pump. Hope this helps for now...
Fredel
Wade787b
Sep 29, 2015 01:15 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
