BIG PROBLEM! Need help
Old Jun 18, 2002 | 01:32 PM
RODS92Z's Avatar
OK I just installed a new fuel pump. The gas guage works when key is on, but buries the needle when the car is running. Now just a couple of minutes ago the car just died out of the blue. No sign of struggle, just quit. Now when I turn the key to on positon the service light doesnt come on and the fuel pump doesnt kick in. The car still cranks good. What the hell happened? Need help ASAP!!! Just when I'm selling the f*cken thing.
Old Jun 18, 2002 | 02:03 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
sounds like a fuse blew. also is it a ac delco pump?
Old Jun 18, 2002 | 02:04 PM
Engine: ls1, LB9
what guage f/p?
Old Jun 18, 2002 | 06:57 PM
RODS92Z's Avatar
It is the fuel guage. Now I found the fuse by the battery was blown so I replaced it and turned the key to on position and the service light came on for a second before the fuse blew again. The fuel pump is a holley/walbro pump. Now something is shorting out. Is it the fuel pump wires? And why is my guage only work with car off and in on position, Then when car runs its buried? Its gotta be a ground someplace, but where? I Sold the car and I need this fixed very soon.
Old Jun 18, 2002 | 10:14 PM
Engine: ls1, LB9
I would first disconnect the plug at the tank and see if there is still a short. it sounds like something may be messed up at the sending unit. also I think it will peg. the fuel gauge when disconnected. (not sure with out looking)
Old Jun 18, 2002 | 11:03 PM
Swapmaster's Avatar
Yea, sounds like a short in the wiring to the tank, or the pump
ground is hooked to or grounded to one of the sending unit wires.
Old Jun 19, 2002 | 12:17 PM
RODS92Z's Avatar
thanks guys. Found the problem. Stupid ground wire. Something so stupid.
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
overdriv
Aug 20, 2015 03:52 PM
sreZ28
Aug 14, 2015 07:48 PM
