autobox
Old Jun 20, 2002 | 04:01 PM
archie george's Avatar
autobox
hi can any one tell me why my auto box is so high geared the car is a 1986 camaro z28 305 ci with auto box 700r4 the reves are at 3000 and the car is at 120 mph how can this be
hope you can help
yours arch
Old Jun 20, 2002 | 08:50 PM
Arawn's Avatar
Sounds about right. Though that's mostly your rear-end gear. In 86, 2.77 was the most common rear-end gear. My 86 will do 80 at about 2000, but I always looked at the road and the rear-view mirror more then the tach at 120mph
Old Jun 21, 2002 | 02:56 PM
Jza's Avatar
Jza
It's not high geared. Third is direct drive (1:1) which is what most final gears are, and the overdrive is .70:1 which is on average, lower than most overdrive transmissions. And the 700R4's 1st gear is more agressive than most GM transmissions.
The 700R4 is, however, reknowned for it's incredibly wide 1-2 ratio gap.
ts210
Jun 11, 2015 07:28 AM
mrgreggles
Feb 18, 2013 07:20 AM
fin170703
Feb 27, 2007 07:08 AM
scotia
Oct 1, 2002 02:09 PM
