Cleaning plenum and runners
Subscribe
Jun 24, 2002 | 11:29 AM
I don't have a hot tank or parts washer. I'd like to get most of the carbon and oil out the the plenum, runners and manifold. Purple stuff is supposedly bad for aluminum, so I tried soaking the runners in dish soap and water - I guess dish soap also is bad for aluminum because they look awful. So, how do I clean everything out with hurting the aluminum?
Reply 0
Jun 24, 2002 | 11:47 AM
get something like a dremel with a sanding drum and knock it off that way, while your at it, smooth out all the casting marks.
Reply 0
Jun 24, 2002 | 11:54 AM
Just soak it in warm soapy water overnight, then use a wirebrush and carb cleaner or similar to scrub as much as you can out.
You can clean up the runners with a little steel wool (#00).
Reply 0
Jun 24, 2002 | 01:32 PM
I used a chemical solvent made by Castrol. I don't remember what the name was, but it came in a purple bottle. I think it was called Super Clean, and be careful when using it with aluminum.
Reply 0
Jun 25, 2002 | 10:17 AM
Super clean is great stuff, and yea it can etch aluminum if you dont pay attention
Reply 0
Jun 25, 2002 | 01:25 PM
I used carb cleaner, mag cleaner, and a bottle brush. Inside and out they looked good.
Reply 0
Jun 25, 2002 | 05:25 PM
I have read that oven cleaner works well. I have also used brake cleaner for short bouts and had good results.
Reply 0
Jun 25, 2002 | 10:28 PM
I've used castrol super clean, brake cleaner, some green stuff. Soaking does wonders, but that crap really builds up. I think Ed Maher had a pic of his runners sitting in a dish washer, you could try that.
Reply 0
Subscribe
