air conditioning????
Old Jun 26, 2002 | 12:29 AM
Kandied91z's Avatar
i'm not sure but i think mine needs to be recharged..........anyone know what is involved? do i "have" to go somewhere and if so how much should i be looking at?
i don't want to get rid of it since not having t-tops it's nice to have some cooling factor.......but lately it hasn't been really cooling any.
Old Jun 26, 2002 | 10:44 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Never done it.
If you have r-12 then you may have to take it in to get it either done or converted to r-134.
r-12 is hard to come by. according to autozone it's worth about 28 bones a can but you can only buy it if you're licensed.
r-134 you can buy just about anywhere and you should be able to do it yourself. I believe even wal-fart has a conversion kit.
If you do convert make sure you drain ALL the old stuff out.
Old Jun 27, 2002 | 02:41 AM
Kandied91z's Avatar
thanks for the reply..........anyone else?
Old Jun 27, 2002 | 11:51 AM
Desert86Roc's Avatar
If your system is not cooling, you probably have a leak somewhere and need some r-12. Usually, people forget to run their AC periodically and the seals in the compressor get dry or just go bad and leak. I would have someone leak test the system before you spend the money on filling it up.
If you need any kind of repair (like a new AC compressor because the seals are shot), THEN I would recommend switching to 134a. You will still need to change your accumulator, put a new orifice tube in, flush the system and change the seals before pulling a vacuum and filling with 134a and the correct oil. It is not as easy as "If you do convert make sure you drain ALL the old stuff out".
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
jackhammer
Aug 15, 2015 10:04 PM
