Converting to serpentine
Car: 1991 Camaro Z28
I've got the brackets and belt for a serpent setup.
I don't have a crank pulley however. What years could I get a crank pulley off of to make it work with the rest of the setup?
Any small block? V6s?
Also, is there anything other pulleys I'll need that won't be included in accessories (alt, compressor, p/s, water pump) or won't be included with the accessories.
You'll need all the pulleys off the other car you get and I believe surp started in 88 or 89-92. You could get all the pulleys off the other or buy a under drive pulley set for surp belt set.
I know I'll need all the pulleys, but when buying a alternator, water pump, and compressor they all have the pulleys attached to them. So that's not a problem. What I don't have is a crank pulley, I just need to know what years a crank pulley I can use and which models so I can pull one.
I knew it was 87 or 88. I've got the brackets, a new alt. compressor, and water pump will be bought. So the pulleys for those I'm not worried about. I don't believe a power steering pump will have one however, so I might have to find that one as well.
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
power steering & water pumps do not come with pulley installed. On 88-92 serpentine setup, pulleys on all f-bodies were the same. you can even get a the pulleys off a 88-92 caprice tbi motor. they are the same.
Alright, that's what I needed to know.
So any standard small block chevy serpenetine crank pulley will work. I'll have to find a junk car.
Thanks for the help.
2012sergen11
Oct 13, 2015 07:38 PM
