Stealth Ram or High flow TPI?
Old Jun 27, 2002 | 09:05 PM
Speedyz28's Avatar
Car: 1987 Z28 Camaro
Engine: 355 chevy
Transmission: TH700R4
Hey,
I'm still trying to figure out what kind of combo of intake i should use for my ZZ4 crate engine that i wll be putting in hopefully in 2 weeks....should i just get a high flow base, runners, and a 52mm TB for the ZZ4, or should i invest in the holley stealth ram?....another quetsion....i have a hotchkis Strut Tower brace on my Camaro...will the stealth ram fit under this...is there anyway to make it fit under?......or will i have to take it off in order for it to fit? Thank you...i appreciate the help!
Old Jun 27, 2002 | 09:14 PM
rezinn's Avatar
I doubt the stb will fit with over the stealth ram. I'm sure the stealth ram would be better than an aftermarket ltr setup, especially hp/$ wise. The cost of just the base and runners would probably exceed the total investment for the stealth ram.
Old Jun 27, 2002 | 09:23 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
There is the LT1 intake too. Then you can have your HP and your STB. The LT1 is very similar in HP charateristics to a Miniram (at a cheaper price). A friend of mine (before he made further mods) started with a ZZ4 with a Miniram and it was a great setup.
Further porting of the heads and a different cam and he had a high 12 second car.
Old Jun 28, 2002 | 03:40 AM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
This is a topic I have been debating also. Would a fully ported TPI, I am talking extrude honed/or siamesed base, Siamesed runners and port matched Upper plenum TPI flow even close to an LT1 intake or Stealth Ram?
Old Jun 28, 2002 | 06:15 AM
Speedyz28's Avatar
Engine: 355 chevy
Thanks for the ideas......if i were to go with te LT1 setup....how do i modify it to fit on the ZZ4 or will it just bolt up no problem....I have a 87 Z28 Camaro that the ZZ4 will be going into....of that helps with anything.....Also, do they already sell a LT1 intake, fuel rails, TB, Fuel lines to work with a Gen 1 SBC.....like the ZZ4....or will i have to do this all myself?....Thanks
Old Jun 28, 2002 | 01:11 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
It wont bolt up, and the stock LT1 takes a lot of modifying.
Check out www.lt1intake.com, you can buy pre-modified set-ups there that will bolt rite on, mine is arriving UPS today.
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Dialed_In
Aug 20, 2015 01:45 PM
Sanjay
Aug 12, 2015 03:41 PM
L98GTA87
Aug 11, 2015 06:55 PM
