Analysis of Code 33 errors..
Old Jul 1, 2002 | 11:10 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Ok, here we go...
My setup:
1987 GTA
350 TPI
Superram lower manifold, fully ported upper.
52mm TB
LT4 hotcam
Ported Vette heads, 3 angle valve job, etc
1.6 rockers
24# injectors
Granatelli 255 intank
Vortech T-Rex 255 inline
AFPR set @ 47 idle, 55-56 WOT
1.75" shorties, 3" y pipe -> 3" intermediate to single dynomax race bullet.
I've been battling this code 33 for about 2 months now..
My air intake setup is the HomeDepot Racing version.. 45* elbow, to 6" long PVC to MAF to element (not cone, cylindrical, doesn't taper to a cone at the tip)
I've checked for vaccuum leaks, air leaks.
Replaced relays, replaced MAF.
Played with the TPS and idle settings.
Here's what I've found:
If I *dont* let my car warm up before I leave in the morning, it will throw a 33. Which I assume is caused since the last chip I've burned I set the MAF gm/sec to 48 IIRC..
when setting idle speed, if I set it higher than 850 in park, it will throw a 33 due also to the airflow at idle being > 48gm/sec.
My question is, aside from burning a chip (pocket programmer is now defunct, new one won't be here for a month ) Is there a way to beat this code 33..
If it throws the code, I shut the car off for 5 minutes, it will go away and not come back...
I know I could set the idle down some, but then my car doesn't like stop lights because of my cam..
Also, it may just be coincedental, but my car has been harder to start lately-- almost like I have a bad FP relay, but it's brand new, along with the entire rest of the system. (FP is also fine-- it primes it to about 61 PSI prestart.)
Any ideas
Old Jul 1, 2002 | 02:30 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
No...there is nothing to state that you can't raise the gm/sec limit for the code error to 65 gm/sec. It is only a warning and if you are exceeding it with a cold startup, then change it when you can.
The stock 45 gm/sec (or 40, can't remember exactly) is for a bone stock car. If a 406 would have come stock in the car with aluminum heads and a good cam, etc., then GM would have raised the threshold to NOT set the error.
Just raise the limit enough to compensate for your current setup.
Good luck,
Old Jul 1, 2002 | 03:28 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
I think you misunderstood me....
I am fully aware I can reburn a chip with a higher flow rating for idle, but I can't at the moment because my programmer was broken, and I'm awaiting a new unit.
So i'm stuck with the current PROM until then. I was looking for any ideas to work around this for the time being
Old Jul 1, 2002 | 03:32 PM
Guest
Guest
Posts: n/a
You'll need to mess with the throttle plate angle and TPS setting. Open up the plates a little more, lower the TPS setting to around .3-.35v. Not the best workaround, but it'll do what you need it to.
Old Jul 1, 2002 | 03:49 PM
Engine: LS3
Transmission: 6L80E
Actually, I did understand you...but that was kind of my answer, wait until you can burn the chip again...
I also answered the limit question. My bad, thought that was part of it too.
Uhhh, how about try Madmax's suggestions? Good luck and let me know what fixes it temporarily.
Old Jul 3, 2002 | 12:32 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Did some experimenting:
If I pause for about 10-15 seconds after turning the ignition to the on position, and then turn it to start, it will not throw a code 33 off the bat.. I then have to wait for the car to warm up, and drop to about 800 rpms before I drive.. otherwise it will throw a 33 when I start cruising at a consistent speed under 2200 RPMs....
odd..
I'm still eying my igntion module.. wouldn't be the first time a code is thrown for the MAF and it ends up being a COMPLETELY different problem...
Old Sep 22, 2002 | 06:11 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Digging up this old topic.
The car was down for some time for the summer..Lack of motivation to put in the new torque converter and some other goodies...
But, I solved the code 33 issue today...
After swapping MAFs, new relays, new everything.. I decided to check out the wiring.
I started off pulling back the convulated tubing that covers the harness wires.. Low and behold, two wires were cut/melted.
I got a schematic and recrimped a new connector on.. Boom. Wonderful.
Now.. to figure out why I'm only getting 3.3V @ WOT on the TPS (set at .54 idle) Brand new TPS..
Old Sep 22, 2002 | 10:18 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
are you sure the TB is opening all the way up. mine wasn't i was getting 3.8volts. then i bent the stop tab until i got the reading to 4.5.
Old Sep 23, 2002 | 04:38 AM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
Holy hell... Never thought about that..
I'd put $20 on you being right on that..
Thanks..
Old Sep 23, 2002 | 08:28 PM
mrr23's Avatar
Engine: 360 HSR
here's another thing to check. mine was also hitting the worm gear on the clamp for the inlet boot. stopped it at 3.2v so i rotated the clamp and it went to 3.8v then i bent the stop.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
