help me please 89formula doesnt like bumps
Old Jul 2, 2002 | 04:19 PM
CEDOE's Avatar
89 formula, 5.7 TPI, auto.,no cats,k&n otherwise stock
here is my problem only when crusing at sustaind speeds(any speed) and i hit a bump my engine wants to die on me SES will come on and stay on for a few seconds then go off and the engine will pick up again with the smell of gas for a min or so.
when checking the codes i get a code 33 could the be a loose connection somewhere causing me to lose spark?
doesnt happen all the time(not every bump) and no particular speed or RPMs
tried new cap,roter,wires and plugs already
any ideas??
Old Jul 3, 2002 | 05:38 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
dieing MAF unit or loose connector
Old Jul 3, 2002 | 10:55 AM
Morley's Avatar
Try pulling off the MAF connector and look at the female pins in it. Using a small awl try bending the female "closed" a bit more so they make positive contact with the MAF sensor.
Old Jul 3, 2002 | 12:06 PM
CEDOE's Avatar
pins
i will try that this evening and thanks for the reply!
gta892000
Aug 11, 2019 11:16 AM
Elephantismo
Feb 13, 2019 12:51 AM
Ed1LE
Sep 30, 2018 09:14 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
Chiknhawk
Sep 10, 2015 08:55 AM
