Stock Air Box
Old Jul 7, 2002 | 02:22 PM
Tony86TA's Avatar
Stock Air Box
I was checking this out today. Is is possible to exchange where the canister and air box sit? Put the air box next to the fender with the air inlet sticking in the open area in fender and put the canister where the air box was originally. Has anybody done this yet? It looks like it can be done with minor modification. Maybe turn the mount around that they both sit on and add about 6 more inches of intake hose?
Old Jul 7, 2002 | 09:54 PM
Firebird90V6's Avatar
Option
Well what your saying possible, but the easier i found was to drill to 2, 2.5 inch holes in the canister twoard the front of the canister and then off set that one 3 inches to the left of that one. Works like a charm on my 85 TPI.
Old Jul 9, 2002 | 08:48 PM
SLOW91TA305's Avatar
Yea, i switched the airbox and canister. Of course I replaced my airbox with a k&n.....
Old Jul 9, 2002 | 09:52 PM
Tony86TA's Avatar
Thanks man. I was thinking of putting a open K@N on there too. I wondered about when you wash your car or when it rains real bad, does the filter get wet? If not, thats looks like it is alot less restrictive. What kind of difference in performance did you notice?
Old Jul 10, 2002 | 03:36 PM
Ron Mullins's Avatar
Might not be a real good pic.
Old Jul 10, 2002 | 07:17 PM
Yea, it is definatly less restrictive. I noticed a difference in preformance right away. Didn't have my gtech at the time to test it. Everyone pretty much says 5-10hp. I've checked it after washing my car...still dry. Even if it gets a little wet, its still a filter. This is a very popular mod and I never heard of any water filtration problems. So I would say to definatly get rid of the air box and go with the conical K&N. It looks way cooler and you can even hear it sucking from inside the car.
Old Jul 10, 2002 | 08:33 PM
rhuarc30's Avatar
Interesting, on my firebird the air box was already on the the other side of the emissions crap. I also cut large holes in the air box to let more air in, worked great
Old Jul 10, 2002 | 08:53 PM
Tony86TA's Avatar
Got some great ideas guys. Thanks for the pics.
Old Jul 12, 2002 | 06:37 PM
Sciguyjim's Avatar
I've done similar mods. I designed a custom open air filter without the air box. I've been using it for over a year and I've never had a problem with the filter getting wet in the rain.
Old Jul 12, 2002 | 06:52 PM
Sciguyjim's Avatar
Slow91TA305,
I have a 89 305 TPI. Looking at your photo I don't see any MAF. Is it in there somewhere? I too was thinking of using smooth tubing in the air intake but people I consulted felt that since the airflow is relatively slow at the walls, vs center, the ribs on the stock tubing probably have little effect in causing turbulence. Does the smooth tubing seem to make a difference? Thanks. Jim.
Old Jul 13, 2002 | 12:55 AM
BLUETA's Avatar
Car: 86 TRANSAM
Engine: 406
PUT THE MAF IN THE AREA BETWEEN THE AIR FILTER AND THE RADIATOR CAP. MY MAF (1986) HAD A BEND ON THE END, AND THE K&N HOOKED TO IT. CHANGING TO THE TUBE SETUP, AND PUTTING THE STOCK PAPER ELEMENT ON THE END OPENED UP THE LAST 500 RPM ON MINE. IT WAS LAYING DOWN FROM 4000-4500 RPM. PUTTING THE FILTER OUT IN THE OPEN MADE IT RUN HARDER THOSE LAST 500 RPM. THEN I ADDED THE K&N. IT CONTINUES TO RUN HARD, BUT WILL LESS RESTRICTION, THE SHIFT POINT RAISED FROM 4500 TO 4800. MY TOTAL COST WAS $50.
Old Jul 13, 2002 | 01:00 AM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
I moved mine and it is part of the tech article I wrote. It's in the tech article section of this site under Firebird cold air. You can also find it at
http://87tagta.tripod.com
then go to CAI
Old Jul 13, 2002 | 04:47 AM
Sciguyjim's Avatar
Thanks for the instructions guys. They were helpful.
Jim
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
bryan623
Aug 10, 2015 11:33 AM
marcusaw
Aug 10, 2015 08:13 AM
