Procharger on a 305TPI
Old Jul 9, 2002 | 12:05 AM
pennylessz28's Avatar
Car: www.hrfbody.com
Engine: www.hrfbody.com
I've got an rebuilt 305 TPI and I am thinking about adding an ATI procharger to my little block.
The engine is as stands, 305 rebuilt 43,000 miles, ported heads, 52mm thottle body, 3inch exhaust, headers in two weeks, 8.5 MSD wires & plugs, MSD Blaster coil, distrubutor, new fuel lines, ram air.
I am planning on selecting a new cam soon here, and I am wondering if I should select a new set of heads before installing a procharger. What else might I want to take into consideration befoe installing the procharger??
Old Jul 9, 2002 | 12:50 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
New heads wouldnt hurt at all. If you are getting heads though, get ones with larger than the stock 58cc chambers which are on there now. What this will do is lower your compression, allowing you to run more boost, and lowers the risk of detonation. I would recommend an ATI due to its intercooled setup... basically the safest thing to do.
Good luck!
Old Jul 9, 2002 | 02:30 AM
FormulaGod's Avatar
Visit my friend Mikes site. All it has is headers and a cat back. Stock short block w/100k plus miles running damn strong!!! Runs w/LS1 Vettes all day long. Also, its one of the best looking 3rd gen camaros ive ever seen. :hail:
http://community-2.webtv.net/chancey...k/THEDARKSIDE/
Old Jul 9, 2002 | 03:07 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
What did he drop that puppy, 1.5 Inches? Looks hot! :hail:
Old Jul 9, 2002 | 03:08 PM
What type of heads should i be looking for that will except TPI setup?
Old Jul 9, 2002 | 05:10 PM
90Form350's Avatar
FomulaGod, Where in CT are you from? That camaro was at the Frank Marratta show last year at the Expo Center!
Old Jul 9, 2002 | 08:11 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I have built my 305 for a supercharger and I'm using aluminum L98 heads with my setup. Haven't got the blower yet but I know Willie had good results with this setup.
I'm also running crane compucam (powermax) p#104224, which I like a lot
Rob
Old Jul 9, 2002 | 10:02 PM
Sounds like a good combo, I'll look into finding a set of these heads
Old Jul 10, 2002 | 06:25 PM
88GTAinRI's Avatar
From: Ocean State, lil Rhody, the biggest littlest state in the union, Rhode Island
Car: 1988 GTA Black/Gray
Engine: Blown 355
Did you change fuel pump and injectors when adding supercharger? I just ordered a pro charger for my 350 and don't want her to go lean!
Hank O.
sleprock
Oct 1, 2015 09:39 AM
sleprock
Sep 24, 2015 04:33 PM
-=Z28=-
Sep 24, 2015 10:21 AM
86iroczwv
Sep 3, 2015 06:21 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
