lookin for best combo
Hello ,I'm new to the board. I have a bunch of questions and I want them answered imeditly
Seriously, I 'm building a 355 L98 with stock heads (1.94/1.50) crane gold 1:6 Roler rockers . I need a good choice for a cam and Tpi combo (SD or MAF?)also need a good chip to get me in the 13's to high12's. I will be using 700r4 and 3.42s. The block is a 4 bolt main and is set up for a roller cam. Any Info is greatly appreaciated.
You lack discipline!
The best chip is your own. Check out TRAXION's prom burning article, there is a link to it in the DIY PROM board. I'd go for the SD system so you don't have to buy an expensive MAF sensor and worry about it's restriction to the airflow.
There's a lot of debate about it on the DIY PROM board, I'd suggest you check it out, pay close attention to Grumpy's posts.
roysatikas
Sep 22, 2015 08:15 PM
