Will TPI from 305 work on a 350??
Old Jul 11, 2002 | 11:04 PM
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
Will My TPI set up work on a 350? Would i need to change anything? any help would be great!
Old Jul 12, 2002 | 12:03 AM
Morley's Avatar
The actual TPI intake, runners and plenum will work just fine, they are the same ones as used on the stock 350's. For injectors, if the engine isn't a real powerhouse you'll be fine with the 19 lb ones from the 305, just up the fuel pressure about 5 psi. You should get the 350 knock sensor for it and at least get a scanner and or laptop/software so you can monitor the engine and see how it is running. Then decide if you need to burn a custom chip or not.
Old Jul 12, 2002 | 12:28 PM
SLOW91TA305's Avatar
What about the intake manifold? Can you use the 305 intake manifold on a 350? I heard you could.
if so, would it be too restrictive?
Old Jul 12, 2002 | 01:26 PM
Morley's Avatar
See the first 4 words of the above post.
Old Jul 12, 2002 | 05:52 PM
Does the engine block have to be from a 1987 and up? Im thinking about getting new injectors 23lb for about $300 for all 8.
Old Jul 12, 2002 | 07:27 PM
Guest
Guest
Posts: n/a
The block itself makes no difference, its the heads that matter. If you have an 85-86 base (or a vette base) you'll need the early style heads or vette heads. The later base works on the newer heads with the center 4 bolts at a different angle. The intake base can be modified to work on either setup but requires some minor machining to the center 4 bolt holes.
st.evel07
Aug 13, 2015 06:15 PM
djmarch
Aug 11, 2015 10:22 AM
milk
Aug 10, 2015 06:26 PM
marcusaw
Aug 10, 2015 08:13 AM
drathaar907
Aug 6, 2015 04:20 PM
