AFPR's, what are good ones?
Old Jul 2, 2002 | 09:11 AM
5SIZ's Avatar
Car: 1987 IROC-Z
I wanted to bump up my fuel pressure a bit but I need to get a fuel pressure regulator for my TPI, what is a good affordable AFPR?
Are they hard to install?
and Is it difficult to do?
Old Jul 2, 2002 | 09:18 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Try doing a search, hundreds of opinions have already been posted on this matter.
IMHO, the holley can't be beat. Adjustable with no tools, without even looking, or needing to remove anything.
Old Jul 2, 2002 | 09:51 AM
johndo1707's Avatar
i've heard the holley one is great. i have a tpis one and thats easy and great also. holleys is cheaper
Old Jul 2, 2002 | 10:53 AM
tpi_roc's Avatar
Holley or home made.
Old Jul 2, 2002 | 11:08 AM
5SIZ's Avatar
Car: 1987 IROC-Z
How much is the holley FPR?
How exactly do you raise the fuel pressure any how? I don't know aything about it, I figured since I have a good intake and a sweet exaust I can bump up the fuel pressure.
Old Jul 2, 2002 | 11:18 AM
tpi_roc's Avatar
Haha
So more fuel obviously = better right?
The AFPR is meant for TUNING, not for "See how much fuel I can stuff in that puppy"
Anywho with that aside, the way you adjust is a simple thumb screw, Im sure that summitracing.com has pictures of their offered FPR's. TPiS has pics too, although I dont recommend any of their overpriced paper weight "products"
Old Jul 2, 2002 | 12:08 PM
5SIZ's Avatar
Car: 1987 IROC-Z
Originally posted by tpi_roc
Haha
Did I say I wanted to overflow my engine with Gasoline...... NO!
I was just saying that since I have a good exaust and good intake flow that I would like to "bump up" or "Tune" my air/fuel ratio to compliment them.
p.s. Can someone link me to the Holley FPR? I tried to find it int he summit catalog and Holley site but to no luck.
Old Jul 2, 2002 | 12:50 PM
tpi_roc's Avatar
http://store.summitracing.com/partde...HLY512501'
Chill out hot rod.
Try getting ahold of a scan tool to see how much fuel you do/dont need.
Or take some plug cuts
Old Jul 2, 2002 | 01:31 PM
IROCKER's Avatar
The Holley hands down, and if not that then the homemade one is the way to go. The Holley unit is a bit more money than the others, but the ease of adjustment is definately worth the extra moola.
Old Jul 2, 2002 | 01:47 PM
5SIZ's Avatar
Car: 1987 IROC-Z
What is this home made one you guys are talking about? is there a tech article on it?
Old Jul 2, 2002 | 03:01 PM
tpi_roc's Avatar
There is somewhere I imagine
Its kind of a no brainer, some threads, a bolt, a ball bearing or a quarter and you're done.
Old Jul 2, 2002 | 03:27 PM
IROCKER's Avatar
Here ya go....
http://www.gmtips.com/3rd-degree/dox/tips/afpr/afpr.htm
Old Jul 2, 2002 | 05:36 PM
Brian'sIROC's Avatar
I've got the Crane Cams one and it's a P.O.S. Get the Holley.
Old Jul 12, 2002 | 03:42 PM
Ardels91TA's Avatar
Will an adjustable fuel pressure regulator be a good idea on a TPI305 with an otherwise stock fuel system? I have heard and read that by bumping up the fuel pressure just a few psi, it will result in a few extra horses. Is it worth it? I have a good exhaust and intake, just like 5SIZ. Is it goo/bad for the engine? Will it result in added power? What do you guys think? Thanks!
Old Jul 12, 2002 | 08:11 PM
5SIZ's Avatar
Car: 1987 IROC-Z
Adjusting the FP will on be useful at WOT
Old Jul 12, 2002 | 08:14 PM
tpi_roc's Avatar
only
Old Jul 12, 2002 | 08:30 PM
5SIZ's Avatar
Car: 1987 IROC-Z
only
Thank you
Old Jul 12, 2002 | 09:16 PM
Z28DJP1987's Avatar
On a 305 TPI with the stock FPR is already set to run rich with the ECM at about 47 PSI . So I don't see what you would gain. My opinion.
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
