idle jumping while iac unhooked?
Old Jul 14, 2002 | 11:43 PM
poncho9789's Avatar
I have been having this problem with my 88 it idles up and down quite a bit. It even does this with the iac unhooked. What could cause this? The car has no vaccum leaks and the timing is set at 8*
I can't figure out what could be causing this.
Old Jul 15, 2002 | 12:30 AM
Morley's Avatar
If it does it with the IAC disconnected there is a vacuum leak, you just need to track it down. It could be the IAC itself leaking.
IROCtometal
Sep 20, 2015 11:08 PM
earlpote
Sep 12, 2015 11:55 AM
IROCtometal
Sep 9, 2015 10:01 AM
Jk_Under
Sep 8, 2015 08:13 AM
greenyone
Sep 2, 2015 03:39 PM
