87 Iroc 350 TPI Hesitation Problem
Old Jul 20, 2002 | 10:05 PM
nathan247's Avatar
I have an 87 Iroc-z with a 350 TPI and a 700R4. At idle in neutral it runs great, but when you put it into gear it has massive hesitation and tries to die. If you play with the gas pedal a little bit it will quit and take off like a rocket. It makes no difference if the car is hot or cold, it does it every time. I don't know what is wrong with it. I am thinking it is a sensor but I am not sure. If anyone knows anything about this or has had this problem please let me know. Thanks.
Nathan
Old Jul 20, 2002 | 11:19 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm thinking IAC Valve located under the TB. Take it out clean it up and adjust it and see if it helps. If your ever near cleveland and need help let me know. I have everything you will ever need to fix it.
db057
Aug 22, 2015 08:17 PM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
