TPI leak ?
Old Jul 27, 2002 | 09:46 AM
88IrocConvertible's Avatar
TPI leak ?
I have this not really loud hiss coming from my plenum/TB/front intake base area. BUT its only when the engine is really hot, I mean after I turn it on and let it sit idle you won´t hear anything…. It starts after a couple of minutes driving and you can only hear it “hiss” when the engine is off
It is not a vaccum leak because the car idles correctly. The upper intake gaskets and the TB gasket have been replaced with fel pro ones so that should also be okay.
I am just really trying to find out what is making that sound cause its some what annoying. Any ideas would be greatly appreciated.
Old Jul 27, 2002 | 10:58 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Completely normal, it's the IAC whistling. Every TPI car does it. It becomes especially noticeable once you gut the airboxes.
Old Jul 27, 2002 | 11:03 AM
thanks Ed, once again you solved a problem :hail:
bamaboy0323
Sep 3, 2015 06:07 AM
TheExaminer
Aug 26, 2015 04:59 PM
wayshegoes
Aug 17, 2015 12:00 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
