Car won't start from first crank
Old Jul 24, 2002 | 08:31 PM
Mohammed's Avatar
Car: 88 IROC-Z
Transmission: 700-R4
When its cold it will start from the first crank when its hot it will take 2-3 cranks to start it then the rpm's will keep shaking for 10 seconds then it'll wake up. Fuel pump is working I can here it when I turn the key
help please :hail:
Old Jul 24, 2002 | 09:20 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
same prob here
Old Jul 25, 2002 | 10:39 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Test your fuel pressure. I had a similar problem and it was leaky injectors.
Old Jul 25, 2002 | 10:44 AM
Mohammed's Avatar
Car: 88 IROC-Z
Should it smoke when it starts? Because it doesn't smoke but I can smell fuel from the exhaust when it starts.
Old Jul 25, 2002 | 11:07 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Mine didn't.
Old Jul 25, 2002 | 11:33 AM
Mohammed's Avatar
Car: 88 IROC-Z
Is this going to work for testing
Old Jul 25, 2002 | 11:40 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
As long as it fits your Schraeder valve it should work.
You're looking to see how well your pressure holds with the engine off.
Old Jul 25, 2002 | 11:47 AM
Mohammed's Avatar
Car: 88 IROC-Z
Ok if I order it now I'll receive it after a week. So how can you tell if it’s the injectors from the fuel pressure gauge readings
Old Jul 26, 2002 | 11:42 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
The pressure will leak down. It should hold. The most definite way to find out if your inj are leaking is to actually pull the rail, pressurize the system, and watch.
If your pressure drops on the gauge it could also be your fpr. In this case pressurize the system and pinch your fuel return line. See if the drop stops.
For more info do a search. There are many many threads on this subject. You'll find more info faster as well.
Old Jul 26, 2002 | 12:34 PM
Morley's Avatar
It can also be the check valve in the fuel pump.
Old Jul 27, 2002 | 11:21 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I knew I was forgetting something hence the request to do a search.
Thanks Morley :hail:
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
