ok guys youve helped me from wasteing money before 58mm?
Old Jul 28, 2002 | 01:11 AM
383LT1intake's Avatar
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
do you think i ned a 52mm or 58mm throttle body and which ones are nicer units i have a 383 stroker with afr 195cc heads compition ported 10.4-1 comression 2600 vig stall 1 3/4 hooker long tubes LT1 intake 24# injectors 1.65 roller rockers compucam 2032 and im sure im forgeting something but what size and brand to get thanks
Old Jul 28, 2002 | 02:58 AM
Odyssey's Avatar
I'm getting a 58mm for my 400 with an LT1 intake. If I were you I'd get a 58mm. AS&M, LPE, BBK/Edelbrock, Holley are all good. The BBK being the cheapest of them all.
Old Jul 28, 2002 | 03:01 AM
Odyssey's Avatar
Although I do think a compucam 2032 might be a little small for your motor. I'd look for a cam with at least 220/230 duration and above .500 lift to really take advantage of those AFRS and that LT1 intake. I went with a 240/250 and .520 .520 on mine.
Old Jul 28, 2002 | 10:23 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If you're already running 110mph, and with those heads, 58mm all the way.
Some searches would go a long way to finding people's experiences with the various brands.
Old Jul 28, 2002 | 02:54 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
BBK sucks.... from what i have heard
Old Jul 28, 2002 | 03:30 PM
Car: 92 camaro
Engine: 383 stroker
yeah i did a search last night so i thought id post this to see if thier quality has gotten any better i about ordered one till i did that search last night this board is a g0d send thanks later:hail:
Old Jul 28, 2002 | 04:39 PM
Guest
Guest
Posts: n/a
Better? I doubt it. I didnt get mine all that long ago... apparently they neglected to stick a card in my box that said "DONT REMOVE THE PAINT"
So far, after the painting fix, its been ok. I'd never even think about another from BBK, I'd get one from someone else.
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
jharrison5
Aug 19, 2015 05:53 PM
92purpz28
Aug 11, 2015 02:30 PM
