Need pic of Felpro 1014 head gasket
Old Aug 2, 2002 | 04:27 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
If someone could post a high res pic of the felpro 1014 head gasket or email it to me it would be greatly appreciated.
Old Aug 2, 2002 | 05:12 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
I will have one on Monday...It will be used with my 406 and my Pro-Action heads...
Why do you need to see a pic? It apparently is the gasket of choice for 400 performance applications.
Old Aug 2, 2002 | 05:18 PM
Blackroc86's Avatar
Car: 1986 Iroc
I have installed the heads and I can see a bit of the gasket at the bottom of the head where they dip in a bit. Just want to see the layout without removing the heads in case there is a problem.
Old Aug 2, 2002 | 05:20 PM
Engine: LS3
Transmission: 6L80E
I will have to check, but I am pretty sure that my 406 head gasket (stock) does the same thing.
Where does it stick out?
Old Aug 2, 2002 | 08:00 PM
Blackroc86's Avatar
Car: 1986 Iroc
On the lower edge of the head where the short bolts are. On the old cast head there was only one spot there where it dips in about 1/2 inch in a half circle. On the GMPP fastburns there are two spots like that on each head. It is on the second of those turn ins I can see the gasket.
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
NWAsonoma
Aug 18, 2015 05:45 PM
