accel after market full pump
Old Aug 2, 2002 | 07:08 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
I have an 1987 350 TPI IROC and went to the zz430 well i now need more fuel. So I bought the ACCEL high pressure fuel pump. It is part number (310-74702) what i need to know is this an internal pump or an external pump. and is it alright to splice the wires that conect to the stock pump and run to the new pump inside the tank.
Old Aug 2, 2002 | 07:40 PM
Odyssey's Avatar
So you bought a fuel pump but you don't know what it's really for how it needs to be installed ? Greeeeaaat.
Do you REALLY think that ZZ430 needs more fuel then a stock pump can provide ? I'm running a stock TPI fuel pump and it pumps a lot more fuel then my carb can ever handle.
Old Aug 2, 2002 | 09:10 PM
88blackgta's Avatar
Car: 88 GTA Notchback
Engine: 355
Camaro89rs355, Although you could probably make the 74702 pump fit inside the tank, it was actually designed for use as an external pump. To utilize it properly, you should remove your stock in-tank pump and replace it with a fuel pick-up tube with a strainer "sock" on the inlet of it. You can then mount the Accel pump and use the existing positive and negative wiring to power it. A convenient place to mount it is to the vertical portion of the floor pan directly in front of the left side of the rear axle housing.
Hope this helps.
BTW....Odyssey, not to start a flame war but does any part of your response really answer what his question was? Your carb only requires enough volume of fuel to supply the carb with about 7psi of fuel pressure. His TPI unit needs enough volume to supply the injectors with approximately 43 psi. There's a big difference.
Old Aug 3, 2002 | 03:48 AM
Car: 89 Camaro RS
Engine: 355 TBI
thanks 88blackgta your info is a big help!!!!!!!!! Just one more questoin. do i need to wire it to my stock fuel pump relay or is it post to be on at all time when ever i turn the key on? thanks again for all your help.
Old Aug 3, 2002 | 10:23 AM
88blackgta's Avatar
Engine: 355
camaro89rs355, Wire it exactly the same as the factory pump utilizing the original relay. You can simply splice into the harness at the fuel sender unit and extend the wiring. If my memory is correct, the pump positive will be either tan or gray, the negative will be black and the sender unit wire will be pink. Be sure to solder the connections (no "scotchlocks" or "butt connectors" please) and shrink wrap or tape them very well to prevent corrosion.
Old Aug 3, 2002 | 10:31 AM
Car: 89 Camaro RS
Engine: 355 TBI
Will do thanks alot you been a life saver!!!!!!!!!!!!!!!:hail: :hail: :hail:
Glowsock
Jul 24, 2025 03:15 PM
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
Dialed_In
Aug 20, 2015 01:45 PM
