Spark Problem
Old Aug 7, 2002 | 05:27 PM
87ColdAirIroc-Z's Avatar
Spark Problem
ok,
I can time my car at 6 degrees advanced with the est wire unplugged (in bypass mode). Then the the car will run okay, but a little rough. If i then start the car with the est wire plugged in it will hardly run, i have to keep it running with the gas pedal. I can get it to run a little better if i advance the timing to about 17 degrees, however it still runs pretty bad it spits and sputters and is back firing.
The fuel system is good. i think the spark is good. The rotor, cap, wires, plugs, and ignition module are all nearly new (under 4,000 miles). Please help i haven't had my car running since 4 days out of storage this spring!
Thanks in advance,
jake
Also posted in Tech/ general engine.
Old Aug 10, 2002 | 04:53 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Did it run fine when you parked it?
mddaniel
Sep 8, 2015 05:16 PM
db057
Sep 4, 2015 07:57 AM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
