will changing the Fuel Tank Meter Sender/Connector fix a jumpy gauge?
Old Aug 8, 2002 | 09:47 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
i have to put a new fuel pump in my 89 iroc L98 and was wondering if putting in a new Fuel Tank Meter Sender/Connector
would fix the problem? i am using ac delco parts.
thanks
anthony
Old Aug 8, 2002 | 10:19 PM
Odyssey's Avatar
No it wont. All Fbodies I've been in do the same thing when you break, turn or accelerate hard. It's not the parts themselves it's the design of the whole assembly including the tank.
Old Aug 8, 2002 | 10:30 PM
@ZZKKER's Avatar
i will be sitting still and it will say full tank, then i magiclly have 3/4, all this while sitting still.
thanks
anthony
Old Aug 9, 2002 | 12:29 AM
Morley's Avatar
Check the guage connection where the guage plugs into the instrument cluster. Also if you pull the cluster and flip it over there are some clips there that the guage plugs into, these clips just sit against the circut card for connection and get junk built up between them and the copper traces.
Old Aug 11, 2002 | 12:01 AM
@ZZKKER's Avatar
well im not so sure it is the fuel pump, because i did the flow test , of wich in 15 seconds, it is to flow 1\2 pint, that is equall to 1 pint in 30 seconds, i got 1 pint in 22 seconds. i think that is to much. and also, i put a press. gauge on it and the pressure will slowly rise to about 4 psi and then fall, when i manually turn on the fuel pump.
so could it be the press. regulator?
i am going to start a new thread on this.
thanks keep the help coming
anthony
Old Aug 11, 2002 | 11:38 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Almost all Thirdgens have the fuel gauge jumping problem in turns, acceleration and braking don’t worry about it. The only thirdgens that don't are 1LE's. My bro's 1LE came with a special fuel tank that holds the fuel near the pump in turns acceleration, and breaking. Also the fuel gauge doesn’t jump.
Infested
May 22, 2018 11:56 PM
mustangman65_79
Apr 14, 2017 05:37 PM
perZ
Aug 15, 2015 01:17 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
