my z28 is not starting
i need help, my car is getting fuel i can hear the fuel pump going on , car is also cranking over its not starting tho i tried pulling up codes no codes i have an all stock 305 tpi in a 86 z28 if anyone can help me .......
It could be the TPS. I would check your injectors though. Test them with an ohmmeter. I forgot how many ohms they are supposed to read at. The same thing was happening to me and I had a few bad injectors. Good luck.
