car won't start
Old Aug 9, 2002 | 08:41 PM
kevhill85's Avatar
Car: 84 SWB C-10
Engine: 383
Transmission: 350
car won't start
i have an 88 GTA. i truned the car off and now it won't start . it has the chip in the key . the dash (digtal dash ) won't trun on . but the light under ther dash will come on . the chip in the key show to be 3.92 ohom and the key has 3.70 ohom and it has key #1 for my car . has anyone had this problem before . help help
Old Aug 9, 2002 | 09:19 PM
ZZsmpch's Avatar
I thought if the VATS was the problem, it would set a trouble code and a SES.
Old Aug 11, 2002 | 12:36 AM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
does it turn over, or not do a thing? if it turns over, the vats is not the problem.
Old Aug 11, 2002 | 11:55 AM
kevhill85's Avatar
Car: 84 SWB C-10
Engine: 383
Transmission: 350
it dose nothing at all . like it has no power .
Old Aug 11, 2002 | 11:37 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
if you do a code scan you should get a vats fault code, dont remember the # off hand, but I would think you would be getting lights at the dash, you may also check to see if the rod that runs down the column is still attached to the ignition switch, that may be a problem to, or the rack in the switch could be brokwn, if the rod is still in place make sure it is moving the switch when you turn the key over, Ive heard of this happening but never experienced it.
Old Aug 12, 2002 | 07:09 AM
kevhill85's Avatar
Car: 84 SWB C-10
Engine: 383
Transmission: 350
thank u for all the help guys . i strated the car last night about 12.00am ... lol . it was the vats sys. i bypass the fuel pump kill and the stater kill . the car running again and thank for all u help .:lala: :lala: :lala: :lala: :lala:
Old Aug 12, 2002 | 11:17 AM
monte-ss's Avatar
with the vats system if I remember right the injectors shouldnt have fired either the vats system is supposed to send in a digital square wave and the computer recognizes that to fire the injectors, either way you got it running.
Old Aug 12, 2002 | 11:36 AM
kevhill85's Avatar
Car: 84 SWB C-10
Engine: 383
Transmission: 350
that was the last thing we found that was not runnig . we had to send power there to . there was a brown wire w/white strip on it . one was to the injeactor and the other to the fuel pump . i don't know if this is going to have any after math yet . but the car is going to the deal tommrow . to have the vats fix in it . i just live 2 hour away from the closest dealer . so easy to drive there. if u know of any problems know of doing this let me knmow . i would hate to hurt it any more then it has been .
thank u
kevin hill
Old Aug 14, 2002 | 09:04 PM
@ZZKKER's Avatar
i am having trouble starting my car, it will turn the engine , and i have spark, but my fuel pressure is crap, i replaced the fuel regulator and that didnt fix it. so i am putting a new fuel pump in it, so my question i deal with the vats on cars all the time at work and i thought that it just wouldnt let the motor turn over, so to double check, can my problem be caused buy the vats?
thanks
anthony
Old Aug 14, 2002 | 10:36 PM
monte-ss's Avatar
vats is supposed to not allow engine to crank or the injectors to fire you can rewire the satarter to work the way "pre-vats" cars were set up its not hard but with the vats and a no crank problem its easier to troubleshoot to the vats if you leave everything the way its supposed to be
Old Aug 14, 2002 | 10:48 PM
@ZZKKER's Avatar
yea i know it is easyer to trouble shoot than bypass, i was just making sure that the vats worked the way i thought it did.
Old Aug 15, 2002 | 07:39 AM
kevhill85's Avatar
Car: 84 SWB C-10
Engine: 383
Transmission: 350
to bypaee the vats . i had to add power to the ignition switch. 2nd i put power to the fuel pump and 3rd put power to the injecters . just to bypass the vats . it took forevery to figer that out . mine would not trun over and the dash did not trun on .
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
