O2 sensor ? on '92 TPI
Old Aug 14, 2002 | 09:43 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
Where the O2 sensors on the '92 TPI the single wire type, or where they the 3-wire heated type?
Are the 3-wire heated O2s the same as the Wide Band O2s?
Old Aug 15, 2002 | 04:16 AM
Z_Ghost's Avatar
It’s in the driver side exhaust manifold.
The 3-wire heated O2 is just a heated O2 sensor and not a wide band O2.
Old Aug 15, 2002 | 10:48 AM
tpi_roc's Avatar
Heated 02's are designed for a bit more accuracy at lower engine temps, basically you could go into closed loop sooner with a heated 02.
A wide band is designed for tuning, its accuracy range is "wider" than what a switching 02 is, that way you could accuratly determin that you're running at 12:1, instead of saying you're NOT at 14.7:1 where the stock 02 would be accurate. (I have no clue exactly how far you can go with a stock 02 before your readings are skewed)
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
