LS1 ZO6 Injectors
Old Aug 12, 2002 | 09:44 PM
RGS1260's Avatar
LS1 ZO6 Injectors
My Holley 950 base map calls for 30lb injectors
Could I get away with using 28lb stock ZO6 injectors?
How can I verify that they are actually 28lb injectors?
What is ther fuel pres regulated at?
Can these replace stock Type TPI injectors.
If they are so great why are there so many set on E Bay?
My motors making 450 HP
Old Aug 13, 2002 | 03:35 PM
Odyssey's Avatar
LS1 injectors are way different. They won't fit.
Old Aug 13, 2002 | 03:48 PM
RGS1260's Avatar
What about Z06
Old Aug 13, 2002 | 04:29 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
same result
wont fit
Old Aug 13, 2002 | 04:32 PM
RGS1260's Avatar
Well that explains why nobody talks about it
Old Aug 13, 2002 | 05:36 PM
RGS1260's Avatar
Why wont they fit?
Old Aug 14, 2002 | 06:05 PM
kevinc's Avatar
Car: 1982 Z28
Geometrically, they're the same size as LT1 and SVO injectors...both of which swap into a TPI fuel rail no problemo.
The problem is the lack of a complete groove up top for the fuel rail clip to engage. If you run LS1 injectors, you'll have to either cut the rest of the groove into them or delete the clip.
I'm running Z06 injectors on my Stealth Ram which doesn't use clips. Here's a pic of an SVO injector next to a Z06 injector for comparison:
Old Aug 14, 2002 | 08:34 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
What the base map calls for dosen't matter after you tune it. The tuning will make up the difference by increasing the pulsewide. I run Delco 22#ers with a 950.
Old Aug 14, 2002 | 10:24 PM
RGS1260's Avatar
What size are the ZO6s?
At what presure?
Im will be running them in a stealthram also
Old Aug 15, 2002 | 07:48 AM
kevinc's Avatar
Car: 1982 Z28
They're rated at 28.x (can't recall off hand) at 4-bar, which calculates to 24.x at 3-bar assuming linear flow rate. I'm running mine at 46psi with the injector constant set to 26.2#.
If you're shopping and want the 28.x rate, be sure to get Z06 injectors, not regular LS1 pieces. Regular LS1 pieces, except for '98 ones, are 26.x at 4-bar which calcs to 22.x at 3-bar. And stay clear of truck injectors, totally different electrical connector.
I got mine from the classifieds at ls1tech.com but they're on EBay frequently. The regular sellers post part#s so dig around there and you'll find info.
Old Aug 15, 2002 | 10:43 AM
tpi_roc's Avatar
Well done kevinc, im glad to see a comparison of the two.
Old Aug 15, 2002 | 11:15 AM
kevinc's Avatar
Car: 1982 Z28
Thankya...thankya verra much...
Just pains me seeing us poor GM owners having to use Ford injectors. Now there's an option.
Old Aug 15, 2002 | 11:16 AM
tpi_roc's Avatar
haha
It pains me to see fellow F-body enthusiasts paying $300+ for injectors
I'm running LT1 injectors. I lub 'em
Old Aug 15, 2002 | 11:25 AM
RGS1260's Avatar
Just bought a set of LS1s fo 100.00
It pays to do a little reseach
Thanks Guys
dbrochard
Sep 19, 2015 08:13 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
earlpote
Sep 12, 2015 11:55 AM
Keiffer76
Sep 9, 2015 08:52 PM
