MSD 6A or 6AL
Old Aug 15, 2002 | 09:21 PM
Oscar's Avatar
MSD 6A or 6AL
I have an L98 (350CID) automatics trans. I know the 6AL comes with the rev limiter. I've seen on other threads that you don't need the 6AL for automatics. Is that true? Does my ECM already have a rev limiter? Want to protect my motor.
Thank for the help.
Old Aug 16, 2002 | 06:02 PM
tpi_roc's Avatar
There is still a concern for overrev with an auto if you manually shift your car (like most everybody does when racing) If you're really economically minded there's money saved buying a 6a, but first time you blow your engine you'll wish you had a 6al. Just depends on what fits your needs.
the 6AL is a soft touch rev limiter and would do it a whole lot cleaner than an ecm would (fuel cut off) if it had one.
Old Aug 16, 2002 | 11:52 PM
Oscar's Avatar
Thanks. Iroc.
So, I don't have a rev limiter on my 91' L98?
Old Aug 17, 2002 | 10:59 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The ECM does have one, but its set at like 10,000RPM..
-- Joe
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
james_fearn
Aftermarket Product Review
May 12, 2001 01:20 PM
Kevin91Z
Nov 13, 2000 07:15 PM
spitfire350
Oct 20, 2000 09:48 AM
