Plug Wires and Headers
Old Aug 16, 2002 | 11:04 AM
Ardels91TA's Avatar
Anyone have any ideas or suggestions for routing MSD wires without burning em up on my new Edelbrock headers. The headers are ceramic coated, so that should help, and I got some good wire looms, but the spark plug boot is within half inch of the header tubes in some places. Some places even closer. You think those boots can handle that heat? Any ideas? THanks.
Old Aug 16, 2002 | 01:23 PM
tpi_roc's Avatar
My taylor wires are about the same distance, they've taken the heat pretty well so far
Old Aug 17, 2002 | 04:00 AM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
plugs
accel makes a set of HEADER plugs that are just a tad bit shorter than stock.... they will allow for the extra room needed.... they are actually made by denso and are pretty good... ran them on my car with a 125 dry shot and never had a fouling problem or burnt plug boots
Old Aug 17, 2002 | 04:13 AM
joker37's Avatar
Car: 1989 Iroc
Engine: 5.7
Transmission: TH700R4
if your really that worried about it i think MSD makes some type of heat resistant tape that you can use to cover the plug boots with. i saw it in their parts book once, but didn't really see the need with any of the applications i was using at the time.
msd will send you a catalog if you go to their site, or any good parts shop will have one so you can order what you want.
joker
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
djmarch
Aug 19, 2015 12:07 PM
