Speed Density
Old Aug 16, 2002 | 02:55 PM
LDOGG's Avatar
Speed Density
i keep hearing about a speed density setup instead of a maf on the 87 ta's what do they look like, how do i get one and from where, how do i hook it up, and r they better then the maf's how much more air does it provide
Old Aug 16, 2002 | 05:56 PM
tpi_roc's Avatar
There's a tech article on how to do it off the main page
There's endless debates about whats better if you do a search.
For a quick run down:
Speed density Is the 90-92 ecm for the LB9/L98's (pn 1227730)
It uses a MAP instead of a MAF, becaues of this your intake tract routing possiblilites are endless, you can run without filters, you can run with cold air intake, you can run with ram air, you can run an open element, or whatever you want.
The prom size is twice as big, and because of that you have numerous other calibrations you can make if you get into prom tuning
Those are the two advantages.
The disadvantage is in later years with the better mafs that are out today your measurement of air flow isn't so direct, you measure engine vacuum with SD instead of actual air entering an engine, so accuracy could be brought into question, but practically when comparing a '165 (maf) and a '730 (map) ecm for the thirdgens as your only two options then of the two the technology in the 730 is more than enough to make up for the indirect air flow measurement calculations.
$750 L98
Feb 1, 2025 02:25 PM
Elephantismo
Feb 13, 2019 12:51 AM
jrdturbo
Mar 31, 2016 02:58 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RGB2015
Sep 20, 2015 09:26 PM
