350 TPI issues
Old Aug 20, 2002 | 01:57 PM
Midnyte81's Avatar
Car: 1984 Z-28
Engine: 350(bored 0.060)
Transmission: Probuilt TH700-r4 tranny with the w
Axle/Gears: 10 bolt 7.5" posi 3.42
350 TPI issues
Has anyone out there used 6.0 rods and a high lift cam on a 350 TPI with 305 heads and had a piston shatter on you? Help me please!!!!!!!!!!!!!
Old Aug 20, 2002 | 03:52 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Can you tell me why you would use 305 heads on a large cam, 6 inch rod 350?
Old Aug 20, 2002 | 10:09 PM
TPIGUY's Avatar
OMG
What were you thinking?!
TPIGUY
Old Aug 20, 2002 | 10:39 PM
Midnyte81's Avatar
Car: 1984 Z-28
The heads came with the engine and a local guy said it would not be a problem if I used the heads with a bigger cam That's the last time I listen to him!!!!!!
Old Aug 20, 2002 | 10:41 PM
Midnyte81's Avatar
Car: 1984 Z-28
Oh yes, I just found out that my Edelbrock heads came in. Will the problem I had happen again?
Old Aug 21, 2002 | 12:40 AM
jizzyz28's Avatar
look at your displacement
You won't be able to make 305 heads work to your advantage b/c the compression will be to high to get the power you are looking for. so if those edelbrock heads are for a 305 good luck working at the shop!
Old Aug 21, 2002 | 06:41 AM
Midnyte81's Avatar
Car: 1984 Z-28
Oh, no. I had a f*cked up time the first time with those damn heads, I wouldn't dare buy another set! I bought the heads for a 350.
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
