87 plenum on 89 GTA...which slp runners to get?
Old Aug 21, 2002 | 07:35 PM
AA89GTA's Avatar
Engine: 355 TPI
Well the title pretty much says it... I have an 89GTA but my plenum is a ported 87 or 88, so I don't know if I should get 85-88 slp runners or if I should still get the runners for 89-92. I don't know if the year of the plenum makes a difference in which runners to get? Thanks for the help.
--Aaron
Old Aug 21, 2002 | 08:00 PM
PonchoDoc's Avatar
Do you have the cold start injector set up?
Old Aug 21, 2002 | 08:57 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
did you run it yet? I know the 89 will not work right on the older cars but, I think the 87 will work on the 89 just want to know. like above you only need the 85-88 runners if you have a cold start inj. other wise the 89-up
Old Aug 22, 2002 | 06:53 PM
Jza's Avatar
Jza
So your TPI base is 89 and your plenum is 87 or 88? If that's the case get the 89> runners.
If you just have a TPI system out of an 87 or 88, then get the <88 runners.
You are, after all, bolting the runners to the TPI, not the car. The year of the base is what matters.
Old Aug 23, 2002 | 05:46 AM
AA89GTA's Avatar
Engine: 355 TPI
Ok thanks guys that's what I thought. I have an 89 base in my car so I'll go with the 89 and up runners.
Old Aug 23, 2002 | 07:14 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You're going to need a cap to block off the CSI line on your fuel rails. I'm heading to a place today that's got them (I've gotten a ton of requests from guys on corvetteforum.com), and if you're interrested in one send me an email. Accel gets $60 for a kit, and because you're getting new runners, there's no point in paying that much just for a threaded cap!
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
