accel superram intake
Old Aug 24, 2002 | 04:06 PM
91blackz's Avatar
Car: 91z
Engine: 5.7 TPI
Does anyone have an accel superram intake on their tpi car? I was just wondering what intake to get and so far i like the accel the best but i dont want to waste my money if it doesnt perform well.
Old Aug 24, 2002 | 09:05 PM
L98IROCZ89's Avatar
Car: 1989 IROC-Z
Engine: 350 Vortech Supercharged ZZ4 TPI
The Accel Superram is the more or less the best intake you can get if you are sticking to Tuned Port and not swtiching to LT1 intake or Holley StealthRam.
However, the complete Superram will bog even your 350 down because it is not modded and does not need that much air. You would be much better off spending that $3000 on good set of heads and cam. Then, port your base, plenum and runners (which would be pennies if you do it yourself).
If you are planning on getting a hot motor later on, then you could slide with the Superram now, but it doesn't make much sense and is overkill to the fullest extent on a stock motor.
Old Aug 24, 2002 | 09:15 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
You're better off spending the money on some heads and cam. You can modify the stock tpi unit, check out the siamease tpi intake in the techincal articles. That will definetely wake the car up.
Old Aug 24, 2002 | 09:33 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I agree, I'd get heads and a cam first. Then the SuperRam. Or save up and do it all at once and get a good matched combo. The SuperRam is a great intake, but on a stock or close to stock motor, probably won't make much difference.
Old Aug 24, 2002 | 11:41 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
i have a Super Ram on my z28
you can see it at
http://darcom.home.texas.net/
Old Aug 25, 2002 | 08:54 AM
Poppa Chubby's Avatar
Car: Vert IROC Camaro
Engine: 355ci
Axle/Gears: 9-bolt w/3.45s
DARCOM, I'm checking out your site - BADA$$ car!
Old Aug 25, 2002 | 11:21 AM
92superram's Avatar
The good:
1.flows much better than stock.
2. Gives much more top end power w/o sacrificing too much low end.
3. Broad tq curve works great with 700r4
The bad:
1.Looks like a tranny pan on top of your engine.
2. Doesn't give as much peak hp as lt1 or miniram.
3. Pain in the *** to put on
I'd say go with the lt1 intake. Its 1/3 of the price, and performs great.
Darcom, is the z28 or the viper faster?
Old Aug 26, 2002 | 12:00 AM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
the z28 is faster but i might mod the viper a little becides the viper is just to get the chicks
Old Aug 26, 2002 | 02:19 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Here is how much a nice combo with the superram can wake up your TPI.
Here is a before/after Dyno chart of my '87 Corvette with a Superram/219 cam package also with some new heads and exhaust.
At the wheels...
Stock: 211hp / 315
Mod: 322hp / 362 (not tuned)
We had yet to tune the ECM at that point. Here is the crappy A/F
The car was running MEGA rich down low, so there is a major lack of power below 3500 right now.
Bubbajones_ya
Jul 6, 2024 08:32 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
BAMiller
Sep 14, 2015 06:38 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
