The Stealth Ram article in Super Chevy...
Old Aug 25, 2002 | 05:58 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I have this and can scan it if someone would be willing to host it. I'm not sure what to make of the results. I would have chosen a different cam but what the hell do I know.
Old Aug 25, 2002 | 09:19 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
what issue is it in? I didn't renew my sub. and I'd like to check it out. or could you send me the article to my email?
Old Aug 25, 2002 | 09:37 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
It's in the current issue. I'd prefer to have someone host it.
Old Aug 25, 2002 | 09:53 PM
cobrakiller1989's Avatar
super chevy had EFI in it?!?!?! that might take up some of the advertising room or big block firstgen camaros with big carbs on em
Old Aug 25, 2002 | 11:55 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I can host it, hit me with the scans at razorz28@bellsouth.net
Been waiting for a HSR-topped engine buildup...
Old Aug 26, 2002 | 05:53 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
Alright, here we go:
Page 1
Page 2
Page 3
Page 4
Page 5
Page 6
Old Aug 27, 2002 | 12:43 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
poor numbers
i think that goes to show that the stealth ram can really put high hp numbers down......
i just wish they had afr heads and a comp cam....... so many of us buy afrs it'd be cool to see some dyno articles with more of them instead of others heads.....
but still good numbers.....
Old Aug 27, 2002 | 01:57 AM
NOSFEDGTA's Avatar
RAY 87!!
Are you in the gafba?? if so give me an e-mail. badl98gta@hotmail.com even if your not e-mail me. Im from GA too. As a matter of fact I ahve some freinds coming to race at eatonton this thursday night want to join us? Depending on where you are in atlanta its like 1-2 hours away.. We are all in the gafba.
www.gafba.com
Drew
Old Aug 27, 2002 | 09:10 AM
LT1guy's Avatar
Car: 1987 Trans Am
Hey Drew! Whats going on buddy, haven't seen you in a long time!!!
Old Aug 27, 2002 | 11:47 AM
NOSFEDGTA's Avatar
Joe h ?? If so whats up man long time no see..
Drew
Old Aug 27, 2002 | 01:08 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I know I'll get twisted for this but ...
I'm not impressed AT ALL. 444 FLYWHEEL horsepower with a 391? Gimme a break. That equates to between 355 to 377 rear-wheel horsepower. LT1 guys have been making that with a stock 350 bottom end. I've seen several 400 REAR WHEEL horsepower LT1 cars running stock 350 bottom ends (that equates to close to 500 flywheel horsepower). With a 391 that thing should be well over 500 flywheel horsepower. I would have been impressed with 550 or more flywheel horsepower. Now - what I would like to see is the same engine with a bigger cam and better heads.
Tim
Old Aug 27, 2002 | 03:49 PM
LT1guy's Avatar
Car: 1987 Trans Am
Some more cam would help...the lift is way too low! I'd like to see what it would do with better heads and a solid roller.
Old Aug 27, 2002 | 08:40 PM
esams's Avatar
Yeah, I expect all these early Stealth dyno results to suck. I don't think those Holley Avenger heads are anything to write home about, and I think the cam was a mismatch, too. A lot of trial and error will be done finding the cam that is as perfect for the Stealth as the Lingenfelter 219 is for the SuperRam. Then to tune it ***** on will take more trial and error after that.
Old Aug 28, 2002 | 12:29 PM
Gruvin84SS's Avatar
HSR Hype?
Why exactly did they print that? those number could have been made with a carb/intake combo without the MASSIVE expense of the Holley Stealth Ram/ commander 950 controler package. Did they port match the intake? Why did they run a cam that small? I have to agree with Traxion, i can't be impressed with a motor that makes less than one HP per cube at the Rear wheels.
Maybe i am way off, but do the guys making these engine have any experience with engine building(I know that the HSR is new, but did the manufacturer do any testing, they should know what cam works by now) or do they just stick a part in from the maker with the highest advertising dollar? You don't see too many cars in the mags anymore unless they have a long list of parts that came from their Mags advertisers.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Dragonsys
Sep 25, 2015 03:51 PM
