vortec heads??
Old Aug 28, 2002 | 02:17 PM
fakezcar's Avatar
vortec heads??
has anyone bolted a tpi to a set of vortec heads? Is it possible? I've got the motor and heads are cheap(239 through jegs) and i still want to bolt up the tpi. I've got the machine shop s maybe they can. I'm just wondering if it's reasonable.
thanx
chris
Old Aug 28, 2002 | 03:31 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Yes it's been done. You will need the Vortec base from Scoggin-Dickey for about $400. Another note the valve springs are only good to about .460 lift, much more than that & you will need to upgrade the springs. That low price gets higher real fast.
Old Aug 29, 2002 | 12:03 AM
fakezcar's Avatar
i'm not too worried about springs..it's more the intake..is there any way for a machine shop to modify the stock one?..these guys are good...mayb you've heard of 'em...FAST TIMES MOTORWORKS. they built a buddies motor and a few other drag motors...if it could be done they can do it...it may be easier that way...what do you think...feasible or a waste of time?
chris
Old Aug 29, 2002 | 02:54 PM
IROC57TPI's Avatar
Why re-invent the wheel?
When you have an intake available thats been developed thru research and development and is known to be a bolt on part, why pay someone to make yours work? Not to mention it doesn't have much room for porting...
Pay the $400 for the SD intake and be done with it. Or you could go witha Ramjet intake that will bolt right on and cost a little more.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
