Will a 383LT1 make over 400rwhp??
Old Aug 28, 2002 | 11:56 PM
SMKNGTA's Avatar
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
I have a little extra money to spend on my GTA, so I am trying to figure out what to buy. I was on an LT1 forum and there was a guy with an LT1 making 397rwhp and 368rwtq and ran 11.98@117mph w/ a stock bottom end, stage2 heads, Comp Cams Extreme 230/236 cam, and the normal bolt-ons. There was another guy with a 97 Camaro SS with the same cam and similar mods that made 406rwhp and 375rwtq. the cars with 383's were making atleast 450rwhp, so I would think I could make similar numbers on my car. I was wondering if I could make 400-450rwhp and rwtq with out of the box AFR195 heads, LT1 intake, LT headers, and the right cam on my 383 stroker if I only revved it to 6000-6250rpm and still be able to drive in stop and go traffic all day? Any replys would be helpfull. Thanks
Old Aug 29, 2002 | 12:17 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
YES a 383 LT1 with AFR's will easy clear 400 RWHP,
if he right parts are used :lala:
Old Aug 29, 2002 | 08:38 AM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
After being jerked around to long building my engine, it is getting done by someone else. It'll be done real soon, but now the heads will be completely stock.
What HP do you think I'll be putting out, it will be 383 LT1 intake, inside of intake is all smoothed out,
the cam is the Crane Compucam 2032. 214 / 220, .452 / .465__112 LSA
Edelbrock T.E.S Headers, Borla 3" adjustable Cat-back, catco high flow cat, , custom Cold air intake, burnt chip. stock heads ( ...I know I know)
I also have a totally rebuilt tranny with kevlar bands, servo, etc, 2100 stall converter. and 3.42 posi 4th gen rear.
what power do you think I'll put out at wheels, at crank?
also, will I be able to hang with/beat 4th gens LS1's?????? I hope so.
Old Aug 29, 2002 | 09:47 AM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
Those LT1s with the 400 RWHP spin their motors to 6500 at least. With a 383, yo'd make about 25 more HP at the wheels with the same cam. But you can't be afraid to spin the motor. If you're looking at spinning only to 6000, a Hot cam may be the max for you...but then you won't come close to 400 RWHP.
Old Jan 8, 2003 | 09:18 PM
385LT1's Avatar
Somebody say LT1 with 400 hp.......
where.....
3rd gen fans.... check out the current project car on my web site if you havent already.....
here is a sneak peak
Old Jan 8, 2003 | 09:21 PM
385LT1's Avatar
Thats not a very good shot...
how bout' another...
Project Info is under A.P.E. / Operation Ralley Stroker from the guide bar.....
Old Jan 9, 2003 | 04:19 AM
The Anvil's Avatar
Car: 1989 GTA
Engine: L98 350, dual cats
Transmission: 700R-4
Whoa - nice pic of the X-member! Where did you get that, and how much was it?
Nice!
Dave
Old Jan 9, 2003 | 05:20 AM
385LT1's Avatar
www.paracing.net
Old Jan 9, 2003 | 08:19 AM
86 IROC's Avatar
Why only the 2032 cam? I run a CC306 in my 383 w/ a Mini Ram.
Old Jan 9, 2003 | 08:43 AM
385LT1's Avatar
Nice!
Dave
Here is another......
click to enlarge
Old Jan 9, 2003 | 08:45 AM
385LT1's Avatar
Nice choice 86 IROC.......
Old Jan 9, 2003 | 10:07 AM
86FyrBrd's Avatar
Well after everything that went on I ended up doin the 350 instead as you all probobly know.
But I still have all the 383 parts, but I got the 2032 basically cause thats what everyone on the boards told me.
the 2032 is in the 350 now though. Whats this other came, I'll look into it for the 383 when I build it.
Old Jan 9, 2003 | 10:47 AM
385LT1's Avatar
Internet Racers Supply
CCA-07-306-8 Competition Cams LT1 Magnum Camshaft
Dur@.050 230-244 | Lift .540" - .576" (1.6 RR) |LSA 112 | RPM Range 1800-5800 $239.95
Old Jan 9, 2003 | 10:56 AM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
nope
dude go witha comp custom hyd roller like i did......
mine is a xe282hr cam that has a 112*lsa and small base circle for cam clearence......
i went through pure hell with mine, but i stayed with it and i'm glad i did.. because the first time you hear it loping it makes you feel somthing of proudness knowing you built somthing so great......
yeah, you'll defanantly run into obsticles like cam selection, etc but just sit down and do your math.......... you'll get it...
and the cam that i have has damn good vaccum and brakes are as they was before with the stock cam.... mine is suppose to thump out 475hp and well over 500lbfts of torque..... stealth rammed of course..... so the lt1 intake with easily support that kinda power....
good luck with it and if i can be of any help let me know!!
later adam
Old Jan 9, 2003 | 12:15 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
FyrBird, those stock heads will indeed kill you on that combo. Odds are not good that you'd run much more than mid 13s with sucha beast. Done perfect, sure it could do better. But odds are, you're not going to be anywhere near perfect, at least near the start. That cam is obviously small too, but with stock heads, much more would likely be overkill anyway.
385LT1. Noticed the head studs and wanted to add that from what i've always heard, head studs make it impossible to pull/install heads in the car on a thirdgen. Then again, looks like a well done set-up, so maybe yanking an engine isn't a big deal to you for a head gasket. In the grand scheme of things, it really isnt that hard after all.
Old Jan 9, 2003 | 12:16 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
I have the same goals: 383 w/ 450-500 FWHP w/ lt1 intake. I already have the intake, and that's about it.
Anyway, I'm seeing that the LT1 guys use cams w/ alot more exhaust duration than intake (230/244 for example). This must be because the exhaust port doesn't flow as relitively well as the intake port. I don't think that all that exhaust duration is needed if your building a NA gen 1 sbc.
I plan on using AFR heads w/ the Lt1 intake. AFR heads have good exhaust flow, so extra exhaust duration isn't needed for NA applications. That's why I say go w/ a comp 330/336 or 336/342 or maybe a custom 336/336. There is a similar post about this in the DIY Prom page right now ("cam selection" or something).
Old Jan 9, 2003 | 05:11 PM
385LT1's Avatar
I have never yanked an engine to change a head gasket.....
although, the new studs make it easier to remove, in order to clean the deck...
(BTW: the studs were removed after the heads came off....)
Old Jan 9, 2003 | 05:21 PM
86 IROC's Avatar
That's what I have heard, but from what I can see my combo likes the CC306 just the way it is.
Old Jan 9, 2003 | 06:52 PM
The Anvil's Avatar
Car: 1989 GTA
Ed, a trick I've heard of for that scenario, is to make a cut on the top of the studs so that you can get a flat-blade screwdriver on them. Since head studs are only supposed to go in with a max of 5ft/lbs or so, it should be fairly easy to get them out with the screwdriver trick.
I haven't tried this, just something I heard a few years ago.
Dave
Old Jan 9, 2003 | 07:00 PM
385LT1's Avatar
Look close at these studs.... they are ARP's new product line...
No screwdriver trick needed here...
3/8" Air Ratchet and they will be out quicker than you installed them.
Old Jan 9, 2003 | 08:24 PM
Ed Maher's Avatar
Car: 04 GTO
Nifty stuff. Ain't modern technology great, lol
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
