I need help guys....
Old Sep 1, 2002 | 09:55 PM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
I'm swapping in the stealth ram and new cam along with 24# injectors. I finally got everything together and the thing will not run. When you turn it over it backfires out the intake and the one time we almost had it running it was still really sick. I've been messing with the timing a good bit but nothing I've tried has worked. Do you think the stock computer can't handle it.
Here is the Cam info. : dur.@ .050 I. 230/ E. 236 Lift I. .510/ E. .520 Lobe separation 113*
Old Sep 2, 2002 | 04:16 AM
rezinn's Avatar
I'd say pull the dist out and retime it. Set the timing to the factory 6 degrees at first. Check for vacuum leaks, you should be able to get it running.
Old Sep 3, 2002 | 01:07 AM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
Still not running. No vacuum leaks and the timing is plenty close enough to start. Major backfiring has been ocurring through the intake and exhaust. I think the cam is off.
Old Sep 6, 2002 | 03:55 AM
914Mula's Avatar
Car: 91' Formula
Engine: 383CID
Transmission: t-56
Axle/Gears: 4.10
i got it running tonight and of course it was the last thing I thought of. I didn't adjust the valves right. By the way, the stealth ram rules!
Stratocaster
Aug 15, 2006 06:56 PM
85T/A
Car Audio
Aug 14, 2006 06:07 PM
z28monster
Jul 17, 2006 01:44 AM
WI-Z-Guy
Nov 30, 2005 10:03 AM
parks911
South East Region
Nov 10, 2005 07:47 PM
