drop in fuel pressure
Old Sep 6, 2002 | 05:32 PM
fourspeed's Avatar
i put a fuel pressure gauge on and within 30 minutes it read zero....is this normal.
GM put a new fuel pump in 8 months ago
is there a check valve somewhere that could be leaking down?
thanks for any info
Old Sep 7, 2002 | 06:00 PM
Gruvin84SS's Avatar
sounds like your regulator is leaking by or you have a leaky injector(s). Try pinching the hose on the return and see if it holds pressure, then let go, if it goes down then it is the regulator.
Old Sep 7, 2002 | 06:53 PM
88 IROC BOB's Avatar
I'll bet on leaking injectors. That's the problem I had anyway.
Bob
Old Sep 7, 2002 | 10:33 PM
xformula79's Avatar
If the regulator is leaking by then it usually takes longer to start the car after it has been sitting a while because it takes longer to build the fuel pressure back up
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
