afr flow numbers today
Old Sep 6, 2002 | 10:08 PM
NOSFEDGTA's Avatar
For those of you that remember I am doing a 355 with afrs and a stealth ram. I flowed the stealth ram at 350cfm abaout 2 weeks ago. I flowed my heads today and out of the box they flowed 259 at .550in lift on the intake and the exh. was at 176 at .550.. not to bad for out of the box. I also noticed that they are using differnet valves now. I have had 3 sets of afrs. This my third that I flowed. It was the best out of the box on the exhaust. They now use a manley intake valve and a rev exh. valve thats been rolled back... cant complain. I am going to have them cleaned up to get the ridges out that the cnc machine left and take out a nasty ridge that the exhaust side has on all of them. I think that these heads combined with my stealth ram, 10.2:1 comp and my comp cam 224-230 530-540 cam I should get my mid 12s and then who knows with the 150-200 shot.....
Drew
Old Sep 7, 2002 | 01:09 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Next time flow the heads with the intake bolted up. That will tell if the intake is restricting flow or not.
Old Sep 8, 2002 | 06:34 PM
NOSFEDGTA's Avatar
I flowed my intake already "holley stealth ram" . It flowed 350cfm. I doubt the intake will be much of a restriction.....Plus the intake and heads were port matched to each other....
Drew
Old Sep 9, 2002 | 12:07 PM
tpi_roc's Avatar
the HSR surely should not be a restriction
and why you have out your die grinder GASKET MATCH EVERYTHING
Good luck on your 12's, you deffinatly have the right equipment to do it.
LT1Formula
20
Nov 14, 2015 12:02 AM
spaigo
Aug 21, 2015 07:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
