does relocating the MAT do anything for MAF cars?
Old Sep 8, 2002 | 05:43 PM
tpivette89's Avatar
Car: 2006 Corvette
Engine: LS2
Axle/Gears: 3.42s
last winter i relocated my MAT in my 89' coupe. to my dismay, the kit from TPIS didnt supply enough wire to reach my airbox, so i plugged it into the air inlet tube ahead of the throttle body. ever since i did this mod (along with an airfoil and a 160* stat), ive had a rough idle and can feel it throughout the rpm range. so ive been thinking of putting the MAT back into the stock location. does relocating it to a cooler place really do anything for MAF cars? would i notice a difference at the track if i put it back to stock? alot of people say they noticed their cars became really consistant after relocating their MATs, currently mine is also, and i didnt want to affect this. thanks in advance
Old Sep 8, 2002 | 06:23 PM
89BlueTA's Avatar
No it does not help performance, its only function is for egr operation.
nick
Old Sep 9, 2002 | 12:01 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
The 160 tstat is probably the culprit. ECM is designed to go into closed loop at around 185 degrees. More likely than not, it's switching between open and closed loop as the stat open and closes causing the rough idle.
jaridjohn
Jul 8, 2024 03:49 PM
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
lee01
Apr 9, 2016 01:56 PM
NBrehm
Aug 25, 2015 11:49 PM
