What can I use to clean my bowls
Old Sep 8, 2002 | 07:59 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
I finally got the last parts back from the guy that was gonna build me engine originally, the heads, And they are HORRIBLE inside the bowls, Later tonight I will post a pic of them. What can I use to clean them and QUICK w/ out damaging them , I have to drop them off to the new builder tomarrow.
Old Sep 8, 2002 | 08:06 PM
86FyrBrd's Avatar
Here they are
1)
86FyrBrd's Avatar
Old Sep 8, 2002 | 09:49 PM
ROC-Z's Avatar
Re: What can I use to clean my bowls
Try a laxitive like Exlax or an old fashioned enima.....oh wait you said bowl not BOWEL.
I used engine degreaser and scrub brush on my TPI plenum, runners, and intake. Worked fine. I've heard something called 'Purple Power' is the **** Never tried it.
Your problem may be different. It's baked on, so try oven cleaner. Hell, it'll take paint off if you let it!
Old Sep 8, 2002 | 09:56 PM
86FyrBrd's Avatar
what would have made them so bad, the car ran like a champ with them on there.
I havent looked at valve seals/guides yet, but judging by the rusty stuff in there it looks like the gasket might have been leaking, could that have been what shot some smoke on start up in stead of the guides/seals?
Old Sep 8, 2002 | 10:48 PM
86FyrBrd's Avatar
would a dremel with the wire wheel attatchment work good if I didnt touch the valves.
Old Sep 9, 2002 | 05:35 AM
Odyssey's Avatar
Those would be called "combustion chambers". The bowls are part of the intake tract.
Old Sep 9, 2002 | 11:55 AM
tpi_roc's Avatar
odyssey beat me to it...
Your pictures dont show a "bowl" in any of them
Old Sep 9, 2002 | 12:15 PM
86FyrBrd's Avatar
I know I know, I dont have an excuse for my stupidity, I meant combustion chambers. I was tired I guess when I posted, it was when I got home last night, after being on the road all day, I guess that was it.
anyone have any opinions on the dremel option?
Old Sep 9, 2002 | 12:16 PM
tpi_roc's Avatar
Dremel/die grinder with a cartridge roll and an old valve...
you can smooth out the casting for more detonation tollerance
Its worth the 30min-1hour at the bench if you just do some quick clean up.
Old Sep 9, 2002 | 12:31 PM
86FyrBrd's Avatar
old valve? for what
Old Sep 9, 2002 | 12:36 PM
tpi_roc's Avatar
To protect your valve seats while you grind around your combustion chamber
You dont want to scar a valve you're going to use, and certainly dont want to damage the seat
Old Sep 10, 2002 | 12:22 AM
Kevin 88's Avatar
Car: 88 Corvette
Engine: 400, AFR heads, ZZ9, SuperRam, 730
Transmission: Slushbox
Oven cleaner such as Easy-Off eats aluminum, so don't use that.
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
