400 tpi
Old Sep 10, 2002 | 10:21 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
400 tpi
i have an 89 gta 350 tpi i want to put a 400 small block in with my tpi intake and my centerbolt heads. will this work and what will i need to get or modify to make this run good?
Old Sep 11, 2002 | 03:32 AM
93ND500's Avatar
You will need to consider upgrading you intake components. The stock stuff will choke the 400.
Old Sep 11, 2002 | 09:25 AM
Perry93TransAm's Avatar
Car: 97 WS6 T/A
Engine: LT1 383
Depending on how extreme youre wanting to go a ported plenum and base with larger runners will supply the volume. As far as the heads expertly ported stock iron L-98 heads will work to around 400 HP N/A , But to work on the 400 you will need some steam holes drilled in them, a good machine shop will be able to do this for ya, just provide the 400 gasket for them to use as a template. A very mild cam with this set-up will produce gobs and gobds of torque and sound very docile, but you could stand to go with a bigger cam and not notice any driveability problems (not real big , in the 220 .050 duration range 112 lobe sep, 500 lift ). As a note without porting your stuff out and adding bigger runners the car will still be much faster , but your full potential of the set-up will not be realized until the intakes volume and the heads flow are increased. Oh I forgot to add that the small chamber size on the L-98s will require you to use dished pistons to keep compression down enough for street pump gas. I would go with no smaler than a 20cc dish and a standard fel-pro 400 head gasket.
Perry
Old Sep 11, 2002 | 09:06 PM
demon138's Avatar
thanks alotbut what size injectors will be good
Old Sep 12, 2002 | 08:26 AM
Car: 97 WS6 T/A
Engine: LT1 383
It depends upon the power level youre wanting, if you build it for N/A 400 HP the 24 #ers will be fine, if you go over 450 then I would move up to 30s or 32s , of course a good pump is also a must.
camaro71633
Sep 1, 2015 10:24 AM
downsouthboy
Aug 29, 2015 11:29 AM
lakeffect2
Aug 23, 2015 08:44 AM
Sanjay
Aug 12, 2015 03:41 PM
