TPIS cam gear chewed away MSD distributor gear!
Old Sep 17, 2002 | 02:02 AM
Cm87pta's Avatar
The last few weeks I had my car miss-firing, so I went through plugs, wires and then some. Car continued to do so until one day it miss-fired soo bad that the car back fired and went dead. Well took it to a local shop and my TPIS cam destroyed my year old MSD distributor gear. Has anyone faced this at all, and does anyone think I should receive some compenstation for either the distributor or the cam, because the shop said the cam gear was wasted too in the process. Any opinions would help.
Old Sep 17, 2002 | 11:34 AM
Morley's Avatar
You didn't use the bronze dist gear did you?
TPIS's cams are billet steel and require a special bronze gear on the distributor. Check out TPIS's site on the cam specs and requirements.
Old Sep 17, 2002 | 07:08 PM
Cm87pta's Avatar
Interesting, but do they offer a bronze gear for MSD distributors? Secondly TPIS said i would be fine with my stock distributor gear and MSD is supposed to be a stock replacement. So if my motor isnt wasted do i buy a bronze gear for the stock one? Thanks for the response
Old Sep 17, 2002 | 09:51 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
are you by chance using an aftermarket base? There has been some horor stories that I have heard about the distributor not seating perfectly and being too high when using an after market base. I've seen a few problems on here and have seen this problem first hand with my friends Iroc.
Old Sep 17, 2002 | 11:55 PM
Morley's Avatar
From summit.
all one page | printable page
CRN-11979-1
Image is a representation of this part. Actual part may vary.
$43.39
Vendor: Crane Cams
Product Line: Crane Bronze Distributor Drive Gears
Material: Aluminum and Bronze
Finish: Natural
The distributor gear you need
Chevrolet: 262-502, 200-262 90 degree V6, .500 in. shaft diameter, bronze, distributor drive gear
This drive gear is made from high silicon copper alloy and is precision-machined. Most roller cams need this distributor gear, unless they have an iron gear pressed onto the cam.
Sold individually.
Copyright © 2002 by AUTOSALES, INC. dba Summit Racing Equipment
Old Sep 18, 2002 | 08:18 PM
Cm87pta's Avatar
EEWW yeah i'm using an edelbrock base, and when i talked to TPIS they said that usually with aftermarket bases you have to check distributor length so it does seat properly. My question is i ran this MSD distributor with an edelbrock base and had no problem with the stock cam. TPIS also added there is no need for a bronze gear that there flat tappet cams are made of the same material as factory cams are. I saw the distributor gear and only one side is wasted not the entire gear?
Old Sep 19, 2002 | 12:58 AM
Morley's Avatar
My bad. Saw TPIS cam and automatically assumed roller. But the effect you saw is basically what you get using a stock iron gear on a billet roller cam.
Old Sep 19, 2002 | 08:02 AM
Brian'sIROC's Avatar
I've heard about that problem happening specifically with the edelbrock bases.
Old Sep 19, 2002 | 08:21 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
exactly only one side is more worn up on the gear then the other side. My friend put the stock distributor in and wham perfect.
Old Sep 19, 2002 | 10:44 PM
Cm87pta's Avatar
Okay so moral of story is I should use the stock distributor when I now rebuild my motor because I drove it for a week with metal floating throughout the motor. But what is the cause for only one side getting worn out?
Old Sep 19, 2002 | 11:31 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
I assume by only 1 side, you are talking about the bottom side of the distributor gear. If so, it's because the distributor is not going in far enough for the gears to mesh properly so the cam gear is eating away the distributor gear. Oil pumps require more force to turn than most people think, especially high volume pumps.
9192camaro
16
Feb 3, 2019 12:21 AM
jklein337
Sep 19, 2018 06:23 PM
midias
Aug 15, 2015 05:07 PM
cstrobel65
Aug 15, 2015 10:19 AM
Sanjay
Aug 12, 2015 03:41 PM
