Distributor Question
Old Sep 29, 2002 | 04:10 AM
zerotosixtyV8's Avatar
Car: Camaro
If I were to swap out intakes, how would I remove the distributor? I bet it's probably something simple but I am don't know what would need to be done.do you just remove the cap? or is it more complex than that?
Old Sep 29, 2002 | 05:20 AM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
More than that. I just took out my dist. tonight. There is one bolt that holds it down. You will need to buy a special tool to get to it though. Autozone carries it in there special tool isle, or you could just bend one of your wrenches. It's located directly under the dist. Take off the cap and look under the dist. from the passenger side and you will see it.
Old Sep 29, 2002 | 05:35 AM
rdog30's Avatar
Car: 85&95 Trans am
oh yeah. one more thing. Don't forget to mark the rotor to the dist. housing and the dist. housing to the intake. This way you won't have to reset your timing.
Old Sep 29, 2002 | 06:09 AM
ZZsmpch's Avatar
Marking the dist. will get you close, but you shouldn't count on just a few marks. Get a dial-back timing light, read the instructions that come with it, and set the timing with the light. Any time you pull the distributor, you need to set your timing with a timing light. You can get a cheap one from walmart for $20.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
